Help! WP gasket removal from engine ?
Old Aug 1, 2008 | 07:52 PM
MikeC4's Avatar
MikeC4
Default Help! WP gasket removal from engine ?
Guys,
My WP bearings are toast and it destroyed the Opti in the process. Anyway, I am old school and I am trying to remove the old gasket material from the fron to the engine with a single edge razor. What a major PITA !! Is there a special tool or easier method to get the old crap off. It is not coming off easy like some other cars I've done. It must be the old permatex making it so difficult....
Here's a pic of the WP bearing failure :
Old Aug 1, 2008 | 08:02 PM
janarvae's Avatar
janarvae
I've used this a couple of times: http://www.sears.com/shc/s/p_10153_1...0P?vName=Tools.
But nothing beats a razor blade, so try this: http://www.sears.com/shc/s/p_10153_1...pecialty+Tools. It is basically a handle that you attach razor blades to. I used a razor blade (in my hand) for removing the old gaskets from transmission internal parts - expect lots of cuts (the old-fashioned way of course) if you do it by hand.
Hope that helps....
Old Aug 1, 2008 | 08:41 PM
schrade's Avatar
schrade
Originally Posted by MikeC4
Guys,
Gonna' be time for a new pump pretty soon I'd say...
I was laid out over my passenger front tire, elbow on the TB gettin' a scrape-on on the block too! Doin' it blind too almost.
Whatcha' need is one of them laser guided smart scraper - or a seein' eye razor!
Don't be scared to shoot a few more pics as you go...
Old Aug 1, 2008 | 08:42 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I have always used a putty knife I sharpen on the grinder. It gives more leverage and has a better handle to grab.
Old Aug 1, 2008 | 10:47 PM
skybolt31's Avatar
skybolt31
I used a SnapOn surface prep tool AT401MC:
http://buy1.snapon.com/catalog/item....re&dir=catalog
I started out using a variety of razor and xaxto knife blades, thinking that I may have to do this job in a parts store parking lot some day and wanting to do it with hand tools. It was a pain so I got out the air tool and had the surfaces nice and clean and shiny in a few minutes.
Old Aug 2, 2008 | 08:19 AM
lilredc4's Avatar
lilredc4
These surface prep tools are availibe at tool rental places if you have you near you. they are the best.
Old Aug 2, 2008 | 08:43 AM
adi4's Avatar
adi4
That is the exact same tool that i use, I also use it for polishing small items, If you use the grey discs they are really fine
Old Aug 2, 2008 | 10:25 AM
MikeC4's Avatar
MikeC4
Thanks for all the good info guys !!
I wonder if a dremel tool would work ??????? I don't know if dremel has an attachment that wouldn't score the aluminum surface though.....these things spin at such a high RPM....
Old Aug 2, 2008 | 11:00 AM
pianoguy's Avatar
pianoguy
You have my condolences - that was the worst part of the job for me, too. I did mine last spring and I think I still have cramps from jockeying that razor blade around in there.
Old Aug 2, 2008 | 11:10 AM
MikeC4's Avatar
MikeC4
Thanks !! Yeah...getting the WP,Opti and balancer off was a piece of cake compared to this gasket scraping nonsense..
Old Aug 2, 2008 | 11:45 AM
skybolt31's Avatar
skybolt31
Thats for sure, I am not one to normally spring the money for SnapOn tools, but a friend of mine let me borrow his and it worked so good, it was worth the money. It taks various scotchbrite pads and it turns slower than a die grinder, just really works good and makes the pain in the neck part of the job a piece of cake.
Old Aug 3, 2008 | 12:07 PM
MikeC4's Avatar
MikeC4
Guys,
Thanks for the torque info. and gasket removal methods. I ended up doing it the old fashioned way, single edge razor and bloody hand. I did wrap the razor with electrical tape to make it easier to handle. After I finished, I flushed the coolant system and refilled with ~70/30 prestone/distilled water.
If I ever do this job again, I will invest in that snap-on surface prep tool. I must have spent an hour or so scraping off that old gasket material.
And that 'aint no fun when it is 103F outside...Arghh
Anyway, job finished. Took it out, drove about 20 miles, let it cool, topped off coolant, checked for leaks, no problems.
Just FYI, I have seen alot of threads about the HB not being keyed to the hub. Well, it is true that it is not keyed in the traditional sense, but there is a raised "barb" on the hub that you match up with the triangular arrow on the HB pully. See the first pic to see what I am talking about.
Hub is oriented at TDC(this makes it easy for Opti coupler install. The "mark" on the
coupler will align at 6:00 o'clock:
OEM Delphi Optispark mounted(Note: job much easier if you remove the belt tensioner which is to right:
Opti Test: BEFORE YOU INSTALL YOUR WATERPUMP.Hook all the electricals up,
and start the engine to ensure your Opti works. It only takes a minute to plug in all the sensors.
There is no risk to damaging anything without the waterpump installed and no serpentine installed.
If you look closely, you can see that I even plugged in the coolant sensor which is just hanging there
WP installed, all buttoned up, ready to go(It's a shame that the Opti dissapears after WP install !!):
Old Aug 3, 2008 | 12:10 PM
janarvae's Avatar
janarvae
Guys,
Thanks for the torque info. and gasket removal methods. I ended up doing it the old fashioned way, single edge razor and bloody hand. I did wrap the razor with electrical tape to make it easier to handle. After I finished, I flushed the system of all old coolant and refilled with ~70/30 prestone/distilled water.
Just FYI, I have seen alot of threads about the HB not being keyed to the hub. Well, it is true that it is not keyed in the traditional sense, but there is a raised "barb" on the hub that you math up with the triangular arrow on the HB pully. See the first pic to see what I am talking about.
Hub is oriented at TDC :
To Help! WP gasket removal from engine ?
