Need help on diagnosing a problem
Old Aug 3, 2008 | 11:03 PM
hotjm10's Avatar
hotjm10
Default Need help on diagnosing a problem
I had my engine rebuild (it only had 48,000 miles but was knocking badly). Since it was rebuild it is difficult to start (it turns over initially and dies, then you have to keep the pedel to the floor and keep the rpm's up to keep it from dying. When driving while cold it misses badly until warmed up, then runs pretty good. Once you turn it off it is just as hard to start even after running it for 30 minutes or longer.
One suggestion was the EGR Valve Temperature Sensor. Does that make sense to you?
Thanks for your help.
Jim
Old Aug 3, 2008 | 11:14 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default missing?
Any codes? Check fuel pressure and MAF sensor. Sometimes MAF takes a dump and doesnt set a code. Unplug MAF and see if it runs better, Good luck!
Old Aug 3, 2008 | 11:19 PM
hotjm10's Avatar
hotjm10
Default Need help
Thanks, I will have him try it. There are no codes.
Jim
Old Aug 3, 2008 | 11:53 PM
schrade's Avatar
schrade
Jim
I think EGR and temp sensor are 2 different critters.
A bad temp sensor could [mis-] inform the computer to believe the motor is still cold, and keep extra fuel goin' through the injectors. Does the gauge for temp indicate warm-up? How's the fuel mileage (this might be an indicator of heavy fuel delivery).
How's the warm-motor idle? Any loping idle? Up and down?
Old Aug 4, 2008 | 01:22 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
What year is the car? Is the engine stock? Could be alot of things going on, do you have an Factory service Manual? They are invaluable in resolving problems like this.
When the engine first starts, do you smell gas?
Old Aug 4, 2008 | 11:04 PM
hotjm10's Avatar
hotjm10
Default Yes, Yes & Yes
Definately smell gas when the car starts up. It is a stock engine (5.7 original engine). The car is a 1989 convertible. I do have the factory service manual ( I purchased for my mechanic because it is definately out of my league, but my mechanic does not have access to the internet so I have to ask the questions).
Old Aug 4, 2008 | 11:53 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default egr temp sensor
The EGR temp sensor is a feedback to the computer that tells it if the pipe gets hot, the egr valve opened, and the system is working.
It doesn't have much to do with running the engine, just throwing a code. If the sensor doesn't get hot, or it stays hot once the ECM calls for the EGR solenoid to shut off the vacuum to the EGR valve to allow it to close, it throws a code.
Your problem could be the distributor module, or the engine computer, or a dozen things.
Your injectors could be bad. Your fuel pump could be going bad.
You have to take fuel pressure measurements when hot, when cold, and when shut off.
You have to start somewhere, so start with th fuel pressure, then move to the electrical.
Old Aug 5, 2008 | 12:00 AM
cwyates4's Avatar
cwyates4
Check your coolant temperature sensor, could be a cheap fix to your problem. Do what is mentioned above as well.
Old Aug 5, 2008 | 09:49 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have your mechanic ohm test the coils on each injector when cold and then when hot.
Until then, search the forum for "multec injectors"
Old Aug 5, 2008 | 12:19 PM
schrade's Avatar
schrade
The FSM is NOT out of your league. Maybe a lower primate might have difficulty...
Your mechanic might be a great guy, and your best buddy, but without internet for Alldata.com, or Mitchell's, he's in the dark on computer-controlled cars (unless he has the CD's in his computer). That includes most cars made for the last 30 years.
To Need help on diagnosing a problem
