L98 Fuel Line question
Old Aug 5, 2008 | 03:13 AM
Yguy's Avatar
Yguy
Default L98 Fuel Line question
I've been working on a header install, and it looks like I'm gonna have to reroute my fuel lines as the #2 tube is in contact with them.
The L98 lines have a short section of rubber hose
in them and they use an industrial style crimp connection. As the steel line meets the crimped connector, there's a flared section in the steel line that I believe is used as a stop when assembling these lines. It looks like a ring on the fuel line. I need to reroute the steel line as it exits the hose connector. If I make a new steel line that is routed correctly, do I need to duplicate this ring type of flare? If so, where
can I get the tool to duplicate this on the new line? I know there are other options available, but I'm short on cash, and bending new lines is more affordable than splicing in braided lines.
Thanks for your help.
Old Aug 5, 2008 | 06:32 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Hey bob, I am considering a change of intake, I have fuel lines all made up for the L98. I used much higher quality lines and the entire thing is complete, from end to end.
PM me and I'll send the lines.
They cost me $150 to make up..make an offer. They are custom fit and will bolt right up, no headaches and very neat.
Old Aug 5, 2008 | 07:29 AM
anesthes's Avatar
anesthes
Are you running those vette-tech headers that bump into everything?
-- Joe
Old Aug 5, 2008 | 07:52 AM
mseven's Avatar
mseven
because of my intake (MRII) the fuel lines enter at the rear of the fuel rail and there was no need to have them run through the front of the motor (6-an earls ends and lightweight braided line).The lines come up between no.6 and 8 cyl., and give plenty of room.
If I understand you, the flairs you mention are for the o rings. You can also use adapters and go to -6an stuff instead of all pipe ends. Making your own w/a bender is easy enough but you will still want a flexable section in there to comp.the motor movement.
Old Aug 5, 2008 | 07:58 AM
jsup's Avatar
jsup
Looks like what I did. Except I took off the wheel well and ran the hoses behind the frame member. Nice and neat MSEVEN.
Old Aug 5, 2008 | 08:05 AM
mseven's Avatar
mseven
I used that area for the new trans lines....(braided line)
Old Aug 5, 2008 | 08:14 AM
anesthes's Avatar
anesthes
Hrmm. My miniram feeds from the front. Weird.
I'm probably gonna sell it though. Thinking of using a victor EFI with a 90mm monoblade.
-- Joe
Old Aug 5, 2008 | 09:12 AM
Aardwolf's Avatar
Aardwolf
You can pull the lines up on the frame then bend them slightly where they hit the front of the tube, then they are good!
Old Aug 5, 2008 | 09:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I just manhandled mine, till they were out of the way.
Old Aug 5, 2008 | 09:57 AM
SCCA VETTE's Avatar
SCCA VETTE
If you are going to have to mess with the fuel lines due to clearance then I would just replace the entire line as shown above using braided line. The rubber hoses on the fuel lines are a known for breaking and spraying fuel all over the headers causing a fire.
If anyplace you need to spend money this would be one that I would not overlook.
Old Aug 5, 2008 | 11:31 AM
Yguy's Avatar
Yguy
-- Joe
As a matter of fact, yes I am. Once I get this f-line figured out it should get a little easier.
j-sup, I returned your pm. Got some interest here.
SCCA Vette, I agree, I'm not gonna put in junk.
My thoughts are to go to an industrial supplier and change out the
rubber lines used for engine movement. Then, to
bend up some steel lines made to fit and be done.
The ring type flare I originally asked about is at the end of the line where the collar crimps the rubber line to the steel.
Thanks for the replies, I appreciate the help.
To L98 Fuel Line question
