Sound coming from #8 area
Old Aug 5, 2008 | 11:54 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Sound coming from #8 area
First it was barely audible, know it is getting worse. Sounds almost like a thumping sound, I had a exhaust leak back there after I put headers on.
Could it be a burnt valve and the pushrod is knocking into the rocker?
Old Aug 5, 2008 | 12:04 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Have you put an automotive stethescope to it? Could help you narrow down the problem.
Old Aug 5, 2008 | 12:08 PM
schrade's Avatar
schrade
Pull 6 plug, and check the squeeze in the hole with a comp gauge. Then try the 8-hole.
Old Aug 5, 2008 | 01:01 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Never thought about stethescope,I will go get 1.
Cant do a compression test really weel, car has 175k miles and last time I checked, the compression was not to good on nbr 8.
Just thought about that, it the valve is stuck open a test would show that.
Thanks all!!!
To Sound coming from #8 area
