Heats up quick.
Old Aug 8, 2008 | 02:13 AM
c4steve25's Avatar
c4steve25
Default Heats up quick.
Hi all ,I have a 89' auto vette w/ 94k and it heats up kinda quick IMO. Before I go to work I start the car up and let it idle till the temp gauge reads 100-110f before I go,well work is about 3 miles tops from home and on a 85 degree day it'll hit atleast 175f+ 3/4's of the way to work..... The gauge on my Firebird 2.8L auto hardly moves in such a short trip but this vette heats up quick and then the fan finally kicks on after or around 225f or so (2.8 has 195 thermo,which I read is same for this vette,both stock)... Would a good flush take care of this or is this normal???? Oil temps dont rise quick either,just the coolant temp goes up quick.
The car runs just fine,did a serious tune up and it helped a bit but I'm still very worried something is wrong. Plenty of power and I'm very happy with the car I just dont wanna be sitting in traffic and catch fire under the hood or something crazy like that.
Any help would be greatly appreciated.
Old Aug 8, 2008 | 09:02 AM
Square's Avatar
Square
How long is the drive to work, in time, not miles?
I live about 3 miles from the higway and I use the highway every time I go to work. If I get caught by a couple of stoplights, I will definitely see 170+.
Also, as I understand it, C4's do NOT self cool below about 35MPH (air temperature dependant), thus if you are putting along at 25-30MPH with stoplights thrown in, the car will not hold any temperature until it hits 225 degrees and the cooling fan kicks on.
As for things you can do to make sure your cooling system is in good order:
- Flush the coolant if you don't know when it was last replaced
- Change the thermostat if you don't know how old it is
- Clean the front of the radiator as lots of road debris collects there
HTH
Old Aug 8, 2008 | 09:07 AM
NEVRL8T's Avatar
NEVRL8T
Your car is running normal.
Old Aug 8, 2008 | 09:08 AM
shamdave's Avatar
shamdave
True Dat, per the Owner manual it does not get out of range (hot) till 250. The fans coming on at 225 and cooling down to 200 is normal. I put in a 160 degree thermo and a performance chip. It kicks the fans on at 160. My car will run no hotter than 215 on a hot humid cincinnati day in traffic.
Old Aug 8, 2008 | 09:59 AM
schrade's Avatar
schrade
I too think your car is running normal. In fact it could indicate very GOOD flow. That is, IF it doesn't continue to climb when you take a little further trip - say 10 - 15 minutes more.
Start it up 10 minutes before you leave next time. Turn the heat on max, and watch the gauge. See what happens...
Old Aug 8, 2008 | 10:25 AM
rick lambert's Avatar
rick lambert
Best advice, check for debris between the radiator and condensor...you'll be surprised at what you find. While the temps you site are normal, I'll bet it will take longer if you just clean the area mentioned.
Old Aug 8, 2008 | 02:19 PM
c4steve25's Avatar
c4steve25
Thanks a lot guys! Sounds like I was just a little paranoid lol. I will take a look and clean out between the condensor and radiator later today.
To Heats up quick.
