ABS self test problem 94 LT1
Old Aug 8, 2008 | 04:41 PM
JohnUKVetteNut's Avatar
JohnUKVetteNut
Default ABS self test problem 94 LT1
hi folks
I have an ABS self test ( i can hear it )happening around 3/5 mph foreward and /or backwards every time the car drops down to that speed ?? i think it should only happen once after start up and not again until ignition off/then on start up again?
problem coming or just ignore it?
JohnUKVetteNut
Old Aug 8, 2008 | 05:51 PM
94z07fx3's Avatar
94z07fx3
I think 4 MPH is the turn off (decel) and turn on (accel) point for our ABS. It is strange that you can hear it happening though. Can you open the ABS hatch (7mm) and make sure that is the sound you're hearing?
Old Aug 10, 2008 | 03:58 PM
JohnUKVetteNut
Yes , I am positive the noise i hear is the self test..have removed the foam insulation around the abs unit behind driverseat to check,
I have now noticed that on 2 occosions over this weekend that when the speedo starts as youmove off it reads 0mph then 4 it failed to register 2 and 3/
any ideas
JohnUKVetteNut
PS i have read my codes and have none at all stored.
Old Aug 10, 2008 | 04:11 PM
94z07fx3's Avatar
94z07fx3
This only qualifies for the "any ideas":
On the top, front, driver's side of the ZF is the vehicle speed sensor. I'm not saying this is your silver bullet. However, it would not hurt anything to remove, inspect, and clean it. Access to the VSS isn't overly generous either.
Old Aug 11, 2008 | 12:48 PM
JohnUKVetteNut
OK will look see...I know where this is as i replaced the clutch myself about 4 years ago ( HEAVY GEARBOX!!) so will remove and clean..see what happens
Thanks for "ideas" could be my silver bullet
JohnUKVetteNut
To ABS self test problem 94 LT1
