One bad injector
Old Aug 9, 2008 | 01:58 PM
bee674's Avatar
bee674
Default One bad injector
Just ohmed injectors cold... all 11.9 to 12.0 ohms. Then tested hot 7 were 12.7 to 12.8, except 1 was 4.2. Can i just replace the bad one or best to do all 8?
Old Aug 9, 2008 | 02:04 PM
cwyates4's Avatar
cwyates4
You can just replace one, but if one is bad now, the others probably aren't far behind.
I'll let Jon take it from here...
Old Aug 9, 2008 | 02:24 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
THANKS CORDA replacing 1 is not a good idea .. here's a whole set of 8 Flow Matched Bosch with a 3 yr warrantee. $169.95
http://fuelinjectorconnection.com/sh...&productId=134
Old Aug 9, 2008 | 04:53 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You can replace just 1. At least then you will have 1 new injector.
Old Aug 9, 2008 | 05:16 PM
StealthLT4's Avatar
StealthLT4
Haha. While that is true, if 1 is bad, the 7 others are probably on their last leg too. Plus, injectors are the sort of thing where you want 8 identical ones. 1 new injector will definitely not flow identically to the old 7, and a new injector isn't much more than getting old ones serviced. I'd get new ones...
Old Aug 9, 2008 | 07:38 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Default Think Of It Like.......
One bad spark plug wire ...... would you just change that bad plug wire when all have the same age?
No.
I look at injectors as a major tune up vs. a minor.
Go all 8, all balanced equally.
That equal balance is a key that so many people overlook on vehicles equipped with multiple injectors...many problems arise from injectors playing out one at a time.
Get some des.III from Jon and dont look back...because there will be people trying to catch up to you!
GL
Jim
Old Aug 10, 2008 | 08:18 AM
the blur's Avatar
the blur
Jon,
what is your email address?
thx
Old Aug 10, 2008 | 08:42 AM
geist's Avatar
geist
You can click on his name and scroll to the bottom of the next page, then either send a private message or email.
I've got a set of his Bosch III's too
To One bad injector
