Plenum removal help
Old Aug 10, 2008 | 07:38 PM
Dogstar's Avatar
Dogstar
Default Plenum removal help
I'm replacing the injectors on my '90. I've got the injectors and have d/l instructions so that I can hopefully do the job right the first time. However, I've run into a problem (of course). I have one last bolt to remove (torx) before I pull the plenum off. The head was stripped. I've tried cutting a slot in the head for a screwdriver, didn't work - too tight. Tried using WD-40, no help. Drilled center (off the mark) and used extracing bit - almost worked. Head broke off. Now I'm left with approx 1/4 of thread around the hole. Thought of drilling but that is just cutting into the alum (port tubes to intake) so I stopped. Can I run a blade between the plenum and the port tubes (for lack of knowledge) to cut the bolt so I can lift the plenum off? I'd appreciate any thoughts and recommendations.
Russ
Old Aug 10, 2008 | 07:47 PM
engle1147's Avatar
engle1147
If that was the last bolt and the head broke off of the thing should come off. The gasket may create a tight bond but if the bolts are out except for the broken off then pull that thing off of there...then use a stud extracter to remove the remaining threaded portion of the bolt that is sticking up.
Good Luck!
Old Aug 10, 2008 | 07:49 PM
janarvae's Avatar
janarvae
Russ
If I am understanding you correctly, you are speaking of one of the 8 upper plenum to runner T-40 bolts? There are four on each side, with an arrangement of 1-2-1 bolts. If these are the bolts, there shouldn't be anything except the runner gaskets in place there. I have my '91 plenum apart to replace the intake manifold gasket and there is nothing on either side between the UPPER runner and plenum mating surfaces (except the gaskets again).
However, the bolt sizes do differ and you will need a specific length bolt to replace it. When you put the bolts back on, make sure to run them through a die so they go in much easier and do not mess up the bolt holes. If you need a specific measurement, shot me a PM as I have the bolts mapped out still with the plenum off. Just be sure to specify which bolt it is, like 'passenger upper middle bolt', etc.
And don't forget to update us after the injector install.
If any of my information is incorrect, someone please inform me.....
Jonathan
Old Aug 10, 2008 | 07:50 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Russ
try a thin hacksaw blade.. It should be the thickness of the plenum gasket.. don't cut into the runners or the plenum.. It should work, Then have the old bolt drilled on center in a drill press and extracted properly.
Old Aug 10, 2008 | 09:41 PM
Dogstar's Avatar
Dogstar
thanks for your responses. The bolt I'm having a problem with is the bottom on the passenger side. Think I will try to cut thru whats left of the bolt so I can pull the center piece up and out. I will keep you posted.
Old Aug 10, 2008 | 10:08 PM
schrade's Avatar
schrade
Yup.
Old Aug 11, 2008 | 01:15 AM
rodj's Avatar
rodj
Because of the clamping effect alone I have never been able to remove the plenum without loosening the runner to base bolts.
In most cases, with long term gaskets it has taken a wack with a hammer to break plenum lose from gasket seal.
Old Aug 11, 2008 | 01:17 AM
schrade's Avatar
schrade
That hardened gasket has lost it's sealing ability, and likely is the source of vacuum leaks...
Old Aug 11, 2008 | 01:47 AM
schrade's Avatar
schrade
I would not use a power tool to cut a bolt in such a place - like Mr Jon said there...
Those vacuum sealing surfaces are CRITICAL.
Old Aug 11, 2008 | 09:10 AM
Sam Lam's Avatar
Sam Lam
Russ:
You asked for advice and here is what I recommend:
1. Remove the runner tube assy on the side with the damaged bolt. Once you remove the lower bolts (manifold), the runner should slide over the damaged bolt. The runner is a bitch to get off and the drivers side is the easy one to remove on my 89.
2. Use a pair of vice lock pliers and grab the OD of the stuck bolt and you should be able to remove the remaining stud.
3. Make sure you use anti-seize compound on the threads when you re-assemble the parts.
The use of a hacksaw blade between the runner and plenum can cause damage to the sealing surfaces of these two parts. I would spend the time to remove the runner and not take a chance on damaging critical part surfaces.
I have removed the plenum on my 89 many times and did not have to loosen the lower runner bolts.
Hope this is helpful to you!
Bob
Old Aug 11, 2008 | 09:14 AM
janarvae's Avatar
janarvae
Originally Posted by Sam Lam
Russ:
Bob
This sounds like a very good procedure. I too did not have to loosen the lower runner bolts, just worked the plenum back and forth enough to disturb the gasket seal.
However, if you already did try the hacksaw method, you may want to go with a long file and knock down any high spots or imperfections you may have caused.
Jonathan
Old Aug 11, 2008 | 10:06 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Russ:
Bob
hacksaw blade is a "shadetree" approach.
Old Aug 13, 2008 | 01:42 AM
Dogstar's Avatar
Dogstar
Here's a little update. Finally some success. I have the plenum off now. I stumbled across a tool in my tool box that resembles a feeler gauge on steriods. It's about 10" long and 1 1/2 wide, with a rounded end and complete with a wood handle. It's sturdy but flexible (that makes a lot of sense). I used it on both sides of the gasket on both sides of the plemun. Once the gaskets were removed, I had plenty of space to run a saw blade down to the bolt I was having problems with. Little if any scaring to the plenum or runners from the blade. 98% of the metal fragments and shavings I picked up with a magnet. A little more clean up, removing the remaining bolt from the plenum then on to replacing the injectors. There's still hope for me yet!
Old Aug 14, 2008 | 11:47 PM
Dogstar's Avatar
Dogstar
Has this turned into a project or what. Here's the next question. Ive read there are 6 bolts on each side for the runners. 3 for each pair/set. On the passenger side, I can see the three on the back runner. Where is the third on the front runners. One over the intake toward the front. One bottom center on the outside. Where is the third bolt?
I can't believe how tight some of these bolts are.
Old Aug 20, 2008 | 01:01 AM
Dogstar's Avatar
Dogstar
Default getting there
Finally, I was able to pull the fuel rail off tonight. I had trouble with another bolt that was seized. On the fuel rail no less. I tried 4 different penetrating oils with no luck. Cut a slot in the head of the bolt and tried an impact screwdriver, no luck. I had to cut the bolt head off to pull the rail. I'll let the threads soak in oil tonight, then tomorrow I'll try my luck with removing what remains of the two bolts I had to cut. Cant hardly wait to get this car back on the road. At times, this has been frustrating. Since I like working on cars, it will be rewarding when the job is finished.
To Plenum removal help
