Cam
Old Aug 11, 2008 | 05:49 AM
vettaim's Avatar
vettaim
Default Cam
Thinking about a cam any suggestions? Ran Comp cams in other engines I have built but not sure what to go with on a TPI engine. Do not want anything wild. I spraying a 150 shot of nos now and want to get a little more perfomance out of the car.
Old Aug 11, 2008 | 06:20 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
What's the question?
What brand?
What spec?
Two questions:
1. What do you want out of the car?
2. What other mods do you have?
Can't answer any questions without that info.
Old Aug 11, 2008 | 09:13 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you want a Comp Cam, call them. It will require an exchange of information to get it right the first time. You could also look at a TPiS cam like a ZZ9. A cam change will require a custom chip.
Old Aug 11, 2008 | 09:37 AM
vader86's Avatar
vader86
Need more information.
Old Aug 11, 2008 | 02:00 PM
dan0617's Avatar
dan0617
no bigger than the LT4 hotcam if running a TPI. Even that is a little too "big". Don't get fooled into the thinking of bigger is better. I have an HSR intake and CC503 cam and almost wish I'd have went with the LT4 hotcam.
Old Aug 11, 2008 | 07:12 PM
hobby0002000's Avatar
hobby0002000
Check out the Comp 268XFI cam pt. # 08-466-8. I would think it would work out great for your application.
To Cam
