Clock and Breadbox
Old Aug 11, 2008 | 07:58 PM
benevolentelephant's Avatar
benevolentelephant
Default Clock and Breadbox
Hi there -
I'm thinking abut fitting a clock in my '84 Vette. It has no clock for some reason, I'm guessing that maybe it was in the original radio? That was gone before I got the car.
ANYWAY......
I thought maybe I'd buy one of those breadbox replacement panels from Mid America, and cut a hole in it to fit a clock. My question is, whether there's enough space behind the panel for the clock to fit?
Thanks!!
Old Aug 11, 2008 | 08:27 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default breadbox
89 vert. I put the flat panel and removed the breadbox. I LIKE the look so much better with the flat panel. The breadbox is tough to get off. Lots of hard to reach bolts. I guess it would depend how thick your clock is.
Old Aug 11, 2008 | 09:05 PM
c4cruiser's Avatar
c4cruiser
The clock is in the radio. You should be able to toggle between the station frequency dispaly and the clock display by pushing the volume ****. Most aftermarket radios also have a clock display.
Old Aug 12, 2008 | 09:37 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yours won't have a VATS module, so you will have lots of room for a LARGE clock.
Old Aug 12, 2008 | 10:20 AM
Kool88vette's Avatar
Kool88vette
You can buy a battery operated clock and stick it on the dash with double sided tape.
Old Aug 12, 2008 | 12:27 PM
markKlein's Avatar
markKlein
I agree, your replacement radio should have a "display time" setting if you look through the manual.
To Clock and Breadbox
