Anyone having O2 sensor problems with headers?
Old Aug 20, 2008 | 08:16 AM
redrose's Avatar
redrose
Originally Posted by Aurora40
If the sensor needs the ground wire for other than just heating, how does the one-wire stock O2 work at all? What I mean is, if the ground is shared, wouldn't a non-heated O2 need two wires? Just trying to understand.
FWIW, the LT5 came with three-wire heated O2's.
one-wire sensors are grounded thru their mounts, just like a spark plug...with much lower voltage in the o2 circuit than the spark system, this proved to be less than ideal, but economics meant waiting till a major change was otherwise reqd, and reduced emissions possible with early "light-off" of the heated sensor made it justifiable...high performance application of heated sensors is just a bonus.
