C5 Brake Upgrade Done (Pics)
Old Aug 12, 2008 | 10:55 PM
BlackHarleyMan's Avatar
BlackHarleyMan
Originally Posted by janarvae
Are those brake lines for your year or for the year of the calipers? Reason being I have a set of SS Earls also for my '91 unopened and don't want to use them if I'll have to buy another set with this upgrade in the future.
I would ASSume that they are for the year of your car as you bought a set of 4 and did not modify the rear calipers/rotors along with the fronts.
Thanks,
Jonathan
Jonathan, when you get brake lines for this conversion you use the C4 brake lines front and rear. They will adapt to the C5 calipers with no issues. I hope that helps!
Great thread and good job on your install, It'll make a HUGE difference in your braking and you'll notice the lack of brake fade that you had with the C4 calipers.
R/Noland
Old Aug 12, 2008 | 11:23 PM
DCP's Avatar
DCP
Looks great! I did almost the exact same upgrade last year & have been very happy with it.
David
Old Aug 13, 2008 | 01:37 AM
Yguy's Avatar
Yguy
Originally Posted by Kubs
Thanks. I assume this will improve even the stock Z51 brake setup??
Yes, in fact I have the Z51 on my '88. The brake bias spring is a very big help. It's a cheap mod and highly advisable if you're gonna be working on your brake system. For full details, contact the tech help at DRM.
I'm gonna let it drop now as it was NEVER my intention to hijack this thread, nor did I intend to steal any thunder, ooohhhs, or aaaaahhhs from Johnnymo63's really cool set up.
Old Aug 13, 2008 | 02:08 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
A very nice job. It looks really . Prompts for sharing all of the info
This is a great example of what the forum is all about.
Old Aug 13, 2008 | 08:12 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Im sorry for hijacking. This is a really cool setup that was done very well!!! I wish I could do the same to mine!
Old Aug 13, 2008 | 08:17 AM
Mekanic's Avatar
Mekanic
Looks good but the rotors don't look much different at all from J55's
Old Aug 13, 2008 | 09:31 AM
DCP's Avatar
DCP
I think the C5 rotors are actually slightly smaller in diameter, but are much thicker & better at heat dissipation.
David
Old Aug 13, 2008 | 12:57 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
Thanks,
Jonathan
Yes, the brake lines are made for my year C4. The earlier C4s may take another part number and definitely use different adapter brackets. All other parts are the same regardless of year. (fronts)
Old Aug 13, 2008 | 02:05 PM
LT4POWR's Avatar
LT4POWR
good thread!
Old Aug 13, 2008 | 05:14 PM
C4happy's Avatar
C4happy
did you have any issues with the ebrake?
Old Aug 13, 2008 | 06:57 PM
abc 123's Avatar
abc 123
Need glasses?
C4 Rotor JL9 .75" thick 12.0 diameter.
C4 rotor J55 1.0" thick 13.0" diameter.
C5 rotor JL9 1.25" thick 12.9 diameter
Pads, larger swept area for the C5. Caliper is bigger able to absorb heat better and dissipate it better.
Old Aug 13, 2008 | 09:43 PM
johnnymo63's Avatar
johnnymo63
The manual said to disable the latch mechanism at the E-brake handle to give the cable room to travel, but when I pulled on the cable, it didn't move any.
Everything still came apart and went back together ok. I don't know why they say to disengage it.?? You can leave the rear calipers on the car to do the pad and rotor change, but it makes it easier to clean and paint.
Old Aug 13, 2008 | 10:21 PM
  #33
Mekanic's Avatar
Mekanic
Originally Posted by abc 123
Need glasses?
sorry I wouldn't see 1/4" and 1/10" on a small picture with no comparison other than memory.
Old Aug 13, 2008 | 10:33 PM
  #34
abc 123's Avatar
abc 123
It was actually .5" thickness and 1.0" diameter as he upgraded from the C4 JL9 brakes.
Old Aug 13, 2008 | 11:34 PM
  #35
blankmantn's Avatar
blankmantn
I'm Jealous......
Old Aug 15, 2008 | 02:32 AM
  #36
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Nice work. I like the new wheels too, really changes the look of the Vette.
Old Aug 15, 2008 | 06:54 AM
  #37
LD85's Avatar
LD85
Originally Posted by johnnymo63
Sounds good. I'll be there Saturday if the weather is decent around 7:00.
Good deal, I will stop in for a little bit @ 7:00
To C5 Brake Upgrade Done (Pics)
Old Aug 21, 2008 | 09:12 AM
  #38
EVOVII_SWE's Avatar
EVOVII_SWE
David
David, what rotors are you using there? Looks like 2-piece?
Old Aug 21, 2008 | 05:16 PM
  #39
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Are the anti-rattle clips anything special from Chevy or are they available at any parts store?
Seems like a very lame question, but I have almost all the parts to do this upgrade and didn't know about the clips.
Upgrade sure looks nice. Bet it performs as well as it looks!
Old Aug 21, 2008 | 09:06 PM
  #40
johnnymo63's Avatar
johnnymo63
I'm pretty sure you can get them at most if not all parts stores.
I got mine from here.
https://www.superchevyperformance.co...les.asp?ID=124
