Starter Noise
Old Aug 14, 2008 | 12:40 AM
c4_4ya's Avatar
c4_4ya
Default Starter Noise
After replacing the starter in my 85, it now makes noise as the engine fires and the starter disengages. I put 3 shims on it, and it still makes the same noise, no change. Am I missing something? Should I just do 3 half shims on the inboard bolt? Thanks!
Old Aug 14, 2008 | 07:07 AM
Vic'89's Avatar
Vic'89
Not sure what you mean here, the shim should go across the starter bolts (both bolts).
Are you getting a grinding sound ? Shims should fix this.
Vic
Old Aug 14, 2008 | 09:13 AM
rodj's Avatar
rodj
Old starter or new?
If it engages without noise ,is reasonable to assume you have shims right for gear / flexplate clearance.The noise on startup indicates the gear is not retracting fast enough and is being driven by the engine.Possibly the bendix spring is weak and not pushing the gear out of engagement.
Old Aug 14, 2008 | 12:22 PM
Square's Avatar
Square
I had a NAPA starter do this to me (88' corvette starter to clear the LT headers on my 86'). It was always quiet on engagement and always made a grinding noise after the engine fired. I took it back and got a replacement starter, which fixed the problem. Same 88' corvette starter, just a different unit.
Old Aug 14, 2008 | 01:08 PM
c4_4ya's Avatar
c4_4ya
Its a new one! I've replaced the starter before (a long time ago) and it didn't need shims and made no noise. So I should return this thing? Thanks!
Old Aug 14, 2008 | 02:56 PM
joeld's Avatar
joeld
Do not put half shims at the inboard bolt. Half shims only go on outboard to move the starter closer to the flex plate. Full shims to move starter away from flex plate. But yes on another starter if the full shims do not help.
Joel
Old Aug 14, 2008 | 10:47 PM
c4_4ya's Avatar
c4_4ya
Joel
is it possible that i effed up my flywheel and now it will always make that noise? I probably only started it a dozen times since the new starter started making the noise.
Old Aug 14, 2008 | 11:23 PM
joeld's Avatar
joeld
The only way to know is to remove the flywheel cover and look at the teeth. I would not think there would be any damage, or very little. But do check before it can get any worse.
Joel
To Starter Noise
