I am running hot, why?
Old Aug 14, 2008 | 04:00 PM
RED UFO's Avatar
RED UFO
Default I am running hot, why?
I was on Woodward last night stuck in the Dream Cruise traffic. This is the first time I have been in stop and go traffic since I bought the car. It didnt over heat but was well over the half way mark and getting near the 260 mark. The electric fans were running but it still seemed to be too hot. Is this normal in a 1991.
I am going to flush but should I consider a cooler t-stat?
Old Aug 14, 2008 | 04:14 PM
vader86's Avatar
vader86
http://temp.corvetteforum.net/c4/vad...erheating.html
and remember the dash gauge isnt linear in the 2nd C4 dash
Old Aug 14, 2008 | 06:47 PM
SAY WHEN's Avatar
SAY WHEN
I would also suggest checking between the radiator and AC condenser for any trash/debri/bugs/leaves that might be blocking air flow thru the radiator.
Old Aug 14, 2008 | 08:59 PM
MK 82's Avatar
MK 82
A thermostat will not help assuming the present one is opening fully.
Old Aug 14, 2008 | 09:14 PM
MikeC4's Avatar
MikeC4
and hose down the radiator and condensor from underneath the car, just like everyone does on there home AC units.
Are you having an unusually hot summer up there in Michigan ? With hotter outside temperatures, heat transfer rate is dimished between the radiator and atmoshere.
To I am running hot, why?
