Sluggish on cold start 94 LT1
Old Aug 14, 2008 | 04:17 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default Sluggish on cold start 94 LT1
When I first start when the engine is cold and I get into it. I will here a popping sound and it takes a couple of seconds for the car to go. I have a new GM opti, plugs and wires within the last 8K miles. When the engine is warm it operates as normal
Old Aug 16, 2008 | 01:11 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
who did the plugs and wires? where the plugs installed with a torque wrench (11 ft lb)?
Presume it did not do this before the the 8k ago parts...
Sounds like a couple of spark plugs are not tight and allowing compression to escape until heat expands and tightens-up the plug -- which would also cause the plug to not fire, so presume the idle is rough at first too, true?
Old Aug 16, 2008 | 01:38 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Check your IAC for being dirty. It doesnt take much for an iac to cause a poor idle. Use sensor safe cleaner and DONT push the pintle in when you take it out, and take it out slowly, not to ruin the gasket.
Old Aug 20, 2008 | 05:07 PM
Nowhere Man
plugs and wires were done by my dad and I. the car will idle fine. and whats the IAC
Old Aug 20, 2008 | 10:50 PM
94z07fx3's Avatar
94z07fx3
The IAC is the idle air controler, a mini throttle that is opened and closed by a stepper motor controlled by the computer. The IAC is what allows the car to idle while the throttle remains closed. The IAC is found right at the throttle body. The computer takes in many variables to decide how much to open the IAC.
Old Aug 21, 2008 | 10:24 AM
SSWEET's Avatar
SSWEET
I had that problem on an 88. Turned out to be injector leak down....
To Sluggish on cold start 94 LT1
