89 no start
Old Aug 19, 2008 | 02:34 PM
sand1's Avatar
sand1
Cruising
Default 89 no start
drive home shut off car an hour later i go to start it nothing, no click or anything. next day it fires right up. this happens quite often and without warning. any thoughts thanx sand1
Old Aug 19, 2008 | 02:40 PM
Inlove's Avatar
Inlove
Did it set any codes? If its an automatic, toggle the shifter the as it may be the Park/Neutral switch.
Old Aug 19, 2008 | 02:45 PM
sand1's Avatar
sand1
Cruising
no codes also tried moving shifter
Old Aug 19, 2008 | 02:58 PM
Inlove's Avatar
Inlove
The times you don't get a "click or anything", do you have power to the headlights, windows go down and up at their normal rate?
Old Aug 19, 2008 | 03:15 PM
jfb's Avatar
jfb
Use the search function under, "VATS".
Old Aug 19, 2008 | 03:40 PM
rick lambert's Avatar
rick lambert
with jfb, but before you do, try another key, or clean your key with alcohol.
Old Aug 20, 2008 | 11:12 AM
DINO84's Avatar
DINO84
My 89 6 spd did that once. I was able to push start it.I replaced the starter enabler relay above the radio and it hasn't happened again.
Old Aug 21, 2008 | 11:03 AM
sand1's Avatar
sand1
Cruising
i cleaned the grounds and it hasnt done it since. i will drive it all weekend and see thanx again
To 89 no start
