SS Different Day
"NEW" wires to sensor, "NEW" sensor. Digital dash reading perfectly normal, reads ambient in garage when cool and gradually runs up to about 194-205 while driving.
I had "Three" different ECM's in the car and they all did the same thing.
I had one ECM that had a loose component and some of the clear coating was gone so I sent it to Cardone for a Reman. Got it back today and it did the same as before. 4 ECM's and same problem.
The car runs fine, its just that the fans run all the time and the SES light stays on.
Has anyone ever had trouble with their CCM and had it replaced because of communication problems? I can go through the CCM diags and they seem to work fine. Turn on outputs and toggle inputs fine, it sets codes and they can be erased.
I have a spare CCM, the problems is that it has about 25,000 more miles registered it it than my car, and of course the VIN is not the same and the VATS is different.
Can the mileage and VIN and VATS be changed by a dealer on a used CCM?
Thanks ahead.
I have a paralell jumper wired into the harness that I can watch the voltage while I drive the car. I run the cable into the car to DVM and I can run Datamaster at the same time.
Datamaster shows temps almost exactly what the dash is reading, I would expect this since DM is displaying ECM info. Digital meter is displaying voltage at the proper level.
From a cold start condition the car needs probably at least 5 to ten minutes to warm up and then set this alarm if it does not reach temp.
This sets the alarm right away. Even if the sensor was gone the car should at least take a few minutes to decide to set the alarm. The alarm is "Running too cool". If it were "Overtemp" it would set the alarm immediately.
I also check temp with a Mr gasket radiator cap and use an infared thermometer.
I also paid to have it scanned with a GM service tool and it reported no problems with coolant system.
This sets the alarm right away. Even if the sensor was gone the carshould at least take a few minutes to decide to set the alarm. The alarm is "Running too cool". If it were "Overtemp" it would set the alarm immediately.
I understand how frustrating this must be but for the record I was not questioning your diagnosis to this point, just hoping I might be able to help, the good luck wishes are sincere.
I am still confused by one thing, your first post seemed to indicate the SES light came on immediately at start up, this one says 5 to 10 minutes?
