Reset ECM after injector install necessary?
Old Dec 20, 2019 | 10:34 AM
383vett's Avatar
383vett
Originally Posted by KyleF
This falls under the "Runs OK" category. You have new injectors, the system needs to re-learn the BLMs across the board. Might as well give it a blank slate. I have to assume you are replacing injectors because there is an issue. Why do you want to start operating the new injectors with information from faulty injectors? The adjustments don't happen immediately. It has to see the conditions and adjust. It should actually start running better after a few drives as it see all the different load/airflow/RPM conditions.
Are you data logging? Where are your BLMs now? Bosch III's are known to need some Voltage offset adjustments (that for some unknown reason) that are not published. For some reason it seems the Iron headed L98 has more issue with this than the Aluminum headed 'Vette motor.
Is re-setting the radio presets that much of an issue? I mean, write them down and put the back in. This can't take more than 5 minutes and it's about safety.
Yes, other tings can happen. The car has electricity at the ready it in circuits. A slipped wrench, accidentally breaking a wire, or other means that could expose a connection could cause an arc spark. This could cause a fire as mentioned or could short or overload other electrical components. I would say it is rare and just the right sequence of events would have to happen to cause damage. I guess I just watched "Final Destination" too many times.
10 years later he probably has it figured out if he hasn't burned up.
Old Dec 20, 2019 | 10:38 AM
KyleF's Avatar
KyleF
There was 3 posts before mine but you chose mine to quote?
Didn't even look at the date of the first post.
Kind of makes me think... why do we tell people to search old threads if it is such a sin to use them?
Old Dec 20, 2019 | 07:12 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Originally Posted by Tom400CFI
Fuel lines are self bleeding, as soon as the fuel pump turns on. Cap has nothing to do with it.
Removing the cap relieves pressure from the tank that could push fuel out of your disassembled fuel rails during an injector swap. Fuel getting pushed out is messy, and a fire hazard.
*****! One time I changed my fuel filter and drained out a gallon of gas (yeah, hard to stop when you keep thinking "maybe just a little more") before moving to draining the tank, didn't even cross my mind there might have been pressure in the tank!
These days, I move to the rubber fuel lines at the tank and clamp those off. Say, that requires me to remove the gas cap, doesn't it?
Old Dec 27, 2019 | 06:45 PM
95BLKVette's Avatar
95BLKVette
If you went from stock 24# to Bosch 3 24# you still need to update the injector map because the new injectors inject at a different duration curve than the old stock ones.....you have to ask FIC for this information.
