How to remove 6spd shift knob?
Old Aug 16, 2008 | 04:59 PM
VtVette's Avatar
VtVette
Default How to remove 6spd shift ****?
I'm at my shop, and my FSM is at my house.
Can someone tell me how to remove the shift **** from a '93 6spd?
I tried to search but every link I click says:
"No Thread specified. If you followed a valid link, please notify the administrator"
I don't need detailed instructions, I just can't see what's securing it and I don't want to break anything.
Thanks,
Old Aug 16, 2008 | 05:07 PM
tpi 421 vette's Avatar
tpi 421 vette
You have to carefully remover the plastic 6 speed pattern indicator piece out of the top of the handle. Then there will be a small square key you pull out underneith that. Kind of like a woodruff key. Then the shift handle will unthread off the shifter.
Old Aug 16, 2008 | 05:10 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
I converted my '87 to a ZF 6 speed, but it should be the same:
Gently pry off the plastic gear pattern cap / diagram. You'll see a silver "T" lock inserted into the handle. I like to gently grab that "T" lock with a pair of small vise grips and tap the vise grips upward with a hammer. The "T" lock should pop out and then you can unscrew the shift ****.
Old Aug 16, 2008 | 05:11 PM
byebyeL98's Avatar
byebyeL98
Beat me to it
Old Aug 16, 2008 | 05:20 PM
VtVette's Avatar
VtVette
Got it!
Thanks!
Old Aug 16, 2008 | 05:33 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Hmm, looks like a PIA, is it?
Old Aug 17, 2008 | 02:51 AM
VtVette's Avatar
VtVette
I thought the same thing but no, it's not once you see it for yourself.
Nice that no matter how many times you remove the shift **** it will always remain in the correct position, no way the threads will wear thanks to the indexing "T" key.
Old Aug 17, 2008 | 08:56 AM
pianoguy's Avatar
pianoguy
Some 800-lb gorilla installed that little "T" key on my shifter - it was in pieces by the time I got it out. When I reinstalled the ****, I just left it out.
To How to remove 6spd shift knob?
