Adjust LT1 Idle?????
Old Aug 16, 2008 | 11:21 PM
blankmantn's Avatar
blankmantn
Default Adjust LT1 Idle?????
The search option does not bring up much.....Does anyone have the correct procedure for raising the rpm's??
Thanks!!
Old Aug 17, 2008 | 12:31 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
For our 94 it is as follows:
slightly depress the gas pedal and then start the car.
immediately take your foot off the gas, and allow to idle for 10 seconds.
turn off car for 5 seconds.
restart car, ECM will re-set the IAC to the correct idle speed.
Old Aug 17, 2008 | 10:56 AM
STL94LT1's Avatar
STL94LT1
If you are wanting to raise the idle from its stock setting, you'll need to reprogram the PCM.
Old Aug 17, 2008 | 05:52 PM
96GS#007's Avatar
96GS#007
To Adjust LT1 Idle?????
