Rear End ratio?
Old Aug 17, 2008 | 12:58 PM
pipe's Avatar
pipe
Default Rear End ratio?
Is there a way to tell what rear ratio I have in my 88 by checking under the console lid with the options and code #s? Looking at my Black Book I think the car has the Z51 or Z01 Package in it with the heavy duty suspension and quick steering box in it. What would the option codes be for the different ratio's? THANKS FOR ANY HELP Pipe
Old Aug 17, 2008 | 01:05 PM
Mekanic's Avatar
Mekanic
G92 is the performance ratio for an auto
Old Aug 17, 2008 | 01:18 PM
pipe's Avatar
pipe
Thanks for the info I just looked at the Black Book again and saw that G92 is the 3:07 ratio. I wrote down all the RPO's when I was down the Garage mmm has a G44 whatever that is. THANKS Mekanic Pipe
Old Aug 17, 2008 | 01:22 PM
pmihaltian's Avatar
pmihaltian
Slingshot
G44 = 3.07:1 rear axle ratio. This is the Performance Ratio for your year.
Old Aug 17, 2008 | 01:29 PM
CFI-EFI's Avatar
CFI-EFI
Z01 is an appearance package for 1988. Z07 is an economy package for 1976-1985 trucks. The Z51 is a performance and handling package, that includes several items, but not a rear axle ratio. Any "Z" RPO is a package of some sort, never a gear ratio. Almost all axle ratios carry a "G" designation. However, not all "G"s are ratios. G80 means positraction, G87 means 8 1/2" ring gear, G92 means performance ratio. But G92 is meaningless because the "performance ratio" varies from year to year and car to car. Look for an RPO with a "G" designation, other than the above.
RACE ON!!!
Old Aug 17, 2008 | 03:45 PM
vader86's Avatar
vader86
G44=3.07, so you got the best available for an automatic.
G92 is meaningless.
Old Aug 17, 2008 | 03:59 PM
94z07fx3's Avatar
94z07fx3
If you didn't buy it new, then the only way to know for sure is to count the propeller shaft turns vs the half shaft turns. New gearing is a popular mod. 2¢
Old Aug 17, 2008 | 07:21 PM
pipe's Avatar
pipe
I found G87 under the lid. I bought it as a project car. It is a Z51 Car. I'm still tryin to find out what some of the RPO #s are. Pipe
Old Aug 18, 2008 | 12:25 PM
vader86's Avatar
vader86
G87 is for 8.5" ring gear. This is for a D44 axle however, which did not come with the car if it is also a factory automatic.
Old Aug 18, 2008 | 05:50 PM
pipe's Avatar
pipe
It's a manual trans car. Is there anywhere besides the Black Book to decipher some of the RPO# and such? THANKS MUCH Pipe
Old Aug 18, 2008 | 06:52 PM
vader86's Avatar
vader86
The C4 RPO FAQ in the general section.
To Rear End ratio?
