Shift Knob Removal on 84
Old Jan 2, 2002 | 11:50 AM
Mnemonic63's Avatar
Mnemonic63
Default Shift **** Removal on 84
Ok.... i understand chevy made the corvette to be the most confusing car in the world to take apart, but how in the hell do i get the shift **** off? I wanna replace the boot and ****, but it is NOT happening!:mad Thanx
-Dan
Old Jan 2, 2002 | 12:13 PM
92Coupe's Avatar
92Coupe
Default Re: Shift **** Removal on 84 (Mnemonic63)
It is actually pretty easy. The square inside button will pop out exposing the inside shaft. Then there is a locking ring on the shaft. You will need locking pliers or pointed pliers to expand the ring and slip it up. The **** will then pull up and off. It may be a little tight but it will come off.
Hope this helps.
Old Jan 2, 2002 | 12:15 PM
92Coupe's Avatar
92Coupe
Default Re: Shift **** Removal on 84 (92Coupe)
Mn,
I forgot to tell you this is the way my 1992 comes apart. I'm assuming the 84 is the same.
Old Jan 2, 2002 | 12:25 PM
Mnemonic63's Avatar
Mnemonic63
yea, i didnt have pliars to take off that ring, so i bent the shaft a bit to expose the ring.i got it off and it still wouldnt come off.... ill try using all my weight pullin it off when i get home. Thanx :-)
-Dan
Old Jan 2, 2002 | 12:28 PM
GRX's Avatar
GRX
Auto or stick?
Old Jan 2, 2002 | 12:53 PM
Mnemonic63's Avatar
Mnemonic63
Default Re: Shift **** Removal on 84 (GRX)
Auto.
Old Jan 2, 2002 | 11:29 PM
92Coupe's Avatar
92Coupe
Mn,
Mine was a little tight the first time but it should pull straight up and off. If you really did bent the shaft, that might have put it in a bind.
To Shift Knob Removal on 84
