Why is this ground point cut off?
Old Aug 18, 2008 | 11:42 AM
edwardpayne's Avatar
edwardpayne
Default Why is this ground point cut off?
This is on the left side near the fans of my 1991 Automatic. It looks like it's cut off and not worn off. Do you know what it is and why anyone would cut it off?
I've had an overheating problem with my engine recently..
http://tills.nu/vette/cutgroundcable/brokenground.JPG
Old Aug 18, 2008 | 11:49 AM
94z07fx3's Avatar
94z07fx3
Are you sure it doesn't go to that screw and star washer on the frame right there? It looks like it simply broke.
Old Aug 18, 2008 | 11:55 AM
Iroc57's Avatar
Iroc57
I think you may have solved your overheating problem
Old Aug 18, 2008 | 12:55 PM
bczee's Avatar
bczee
Those are the Relay and harness for optional HD or Secondary Fans.. if your over heating.. are your primary fans working and coming on? you might want to check them out also.
Old Aug 18, 2008 | 01:05 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It is common for those ring connector to break at that point after someone bends or over torques them. It weakens them and they give. Reconnect it to the obvious spot.
Old Aug 18, 2008 | 01:06 PM
Iroc57's Avatar
Iroc57
Optional HD or secondary fans? I never knew that, on my 91 one is for primary and one is for the secondary.
Where did you get this info?
Old Aug 18, 2008 | 02:47 PM
edwardpayne
Hehe, yes It's obvious it goes to that washer but I want to know what it's there for..
edit: I love your picture thanks for your input!
Old Aug 18, 2008 | 02:56 PM
edwardpayne
No change in operation after connecting that cable, at least on the primary fan which seems to be running all the time even if the AC is on or off or the engine is cold or hot.
Could this cable be for the secondary fan or something? Or perhaps this ground point would be for both relays?
Old Aug 18, 2008 | 04:31 PM
bczee's Avatar
bczee
IROC57, I don't have the Secondary Fan on my C4 either..
I found this out by looking at the wiring drawing and by searching on the forum's... Not all came with the optional Secondary fan. The fan relay are on the driver side on the Radiator support with the secondary fan being in Front of the Radiator/Condensor.
Here is one thread that will explain it (I won't have to re-write the information.
http://forums.corvetteforum.com/show...condary+c4+fan
If I am wrong about anything, Don't worry, someone will slam me about it LOL...
Old Aug 18, 2008 | 07:12 PM
engle1147's Avatar
engle1147
I'm guessing someone (previous owner) added the crimped on connector......due to an overheating problem with the car. These relays, when commanded, close a circuit to ground to start the fans and cool the engine. It looks like the previous owner wanted the fans to run all the time so he bypassed the relay's "turn on/off" function and just landed it directly to a ground point....which is why the fan runs constantly with the ignition key on. This is not a bad thing since the thermostat controls how much water will pass at a given temp anyway.
Old Aug 18, 2008 | 07:27 PM
vette079's Avatar
vette079
I will check out my ´91 aut. tomorrow and see if I have that wire there. Mine is identical to yours I guess. What vin. no. do you have on yours? Mine is 1G1YY2383M5100085. I think it´s built late 1990- early 1991.
Old Aug 18, 2008 | 08:59 PM
Iroc57's Avatar
Iroc57
no sweat
The primary is the upper, secondary is the lower fan. The two relays in the picture control these fans. There is a pusher fan that I can be installed up front but I thought that was only aftermarket. I didn't realize it was available factory.
Old Aug 19, 2008 | 01:58 AM
edwardpayne
Thanks, do that! I don't have my vin available at the moment. I'm curious why my coolant started to boil the other day..
Old Aug 19, 2008 | 04:40 AM
vette079's Avatar
vette079
No such wire in that spot on my ´91, but on the same frame rail like 10 inch/25 cm to the rrear I found a factory ground screw with three wires on it. And looking at your picture it isn´t coming from the relay either but from the wiring harness that goes below it. Water started boiling? What exactly happened?
Temp on gauge to high?
Loss of water?
Old Aug 19, 2008 | 05:19 AM
edwardpayne
Loss of water?
Just driving the highway in 90Km/h a rainy day, no hard driving at all. The car was complaining about Low Coolant so I stopped at a gas station to fill it up but it was already full. 40Km later I felt the AC blowing really cold air so I took a look at the temp gauge and it was near the max point.
Stopped the car and heard the water boiling.. In fear of a blown head gasket and called the tow truck.
I'm going to the car today and I will look exactly where that ground cable goes.. I just have the picture for the moment because the car is at the shop. The mechanic couldn't find any indications of a blown head gasket - lucky me!
edit: no loss of water
Old Aug 19, 2008 | 06:10 AM
vette079's Avatar
vette079
Hot engine in our climate here in Sweden.
1 Possible that the thermostat is stuck in closed position.
2 Check the AC system.
Push and hold the fan upp and down buttons for 6 seconds, it will show -00.
Push the auto fan button (in the middle).
It will show any fault codes.
00 No system faults.
01 Temperature door motor circuit fault.
02 Same as 01.
03 Ambient sensor open.
04 Ambient sensor short.
05 In-vehicle temperature sensor open.
06 In-vehicle temperature sensor short.
07 Solar load sensor open.
08 Solar load sensor short.
09 Low freon detected.
10 UART failure.
If the mechanic disconnected the battery then it will probably show 00.
Old Aug 19, 2008 | 08:44 AM
edwardpayne
02 Same as 01.
10 UART failure.
Yes the battery has been disconnected so it showed 00.
I just went to get the car so I can do the search for myself. His final thought was a bad relay, because when he started the car the fan started directly even if the AC was off from the start. He gave the relay a hit and the fan stopped.
Can I check if the relay is bad or just failing sometimes? The temperature went up high on the parking lot and after a while the primary fan started.
I double checked the water level in the expansion reservoar and it was almost empty in there, just a little on the bottom. My thought is that I need to "burp" the system as many are talking about here on the forum, but I've never tried it.
To Why is this ground point cut off?
Old Aug 19, 2008 | 09:25 AM
vette079's Avatar
vette079
Read my other quote just a few minutes ago on another thread. Ask your mechanic if he can do it or can explain how.
Just checked in my FSM, and there are some air bleed screws on the L98.
One on the right side between the pressure tank and the right intake-runner, second is in the right-upper-radiator-corner (a hose and an access plug).
Old Aug 19, 2008 | 09:40 AM
edwardpayne
To which of your threads are you refering to?
Btw, thank you so much for your help!
Old Aug 19, 2008 | 10:02 AM
vette079's Avatar
vette079
It was a reply with quote to "help with cooling sensor problem", by "heck".
