Damper cost $600 ???
Old Aug 25, 2008 | 11:49 AM
  #41
Sailfish40's Avatar
Sailfish40
Originally Posted by Tom Piper
On the LT1/LT4 stock damper/hub assembly, you shouldn't need a puller for the damper, just to pull the hub.
There should be three bolts holding the damper to the hub, on my '92 you just take these bolts out and remove the damper by hand -- although, I have heard of some where the damper was rusted on the hub.
I should point out, my stock '92 LT1 damper came off without raising the engine. After I put on an LT4 damper, I have to raise the engine to get it out -- the LT4 damper is slightly thicker.
Tom Piper
Tom I can turn the damper by force but it will not come out from the Hub. I removed the three screws and using a long metal rod was able to tap the rod and rotate the damoer slightly. However, I can not get it off....
Old Aug 25, 2008 | 03:33 PM
  #42
86PACER's Avatar
86PACER
Originally Posted by Sailfish40
i tried doing this job ths weekend and could not take out the old damper. can you specife which is the correct Puller? send me model number or part number or something i can use to identify it?
thanks in advance...
I guess it is a tight fit afterall.
Try this one.
Part# 27019
And this is the installer to press it back on.
Part# 27144
Autozone rents both with a refundable deposit.
Old Aug 25, 2008 | 06:06 PM
  #43
MK 82's Avatar
MK 82
What happened to the 2X4 and BFH method?
Old Aug 30, 2008 | 01:34 PM
  #44
Sailfish40's Avatar
Sailfish40
Originally Posted by 86PACER
You're saying this is not the balancer for a '94 LT1?
86pacer, what is the spec/part number or what have you for the crank shaft bolt #43 on this picture?
looks like i need one...
