Vortex rammer system?
Old Aug 18, 2008 | 08:18 PM
c4 run's Avatar
c4 run
Default Vortex rammer system?
I have read about it and the specs..who has it? How hard it is to install? And most of all how much gain did you get. Thanks for info guys.
Old Aug 19, 2008 | 02:03 PM
rickneworleansla's Avatar
rickneworleansla
http://forums.corvetteforum.com/show....php?t=2109338
Old Aug 19, 2008 | 05:20 PM
pipe's Avatar
pipe
It's not hard at all to install. I used a Dremel tool with a large cutoff wheel attached to it to cut through the upper radiator shroud. It makes a nice clean cut. They give you a template of where to cut with it. It's a good idea but alot of guy's complain that the underhood heat warps the air box bad then it won't seal right. I guess i've been a lucky one and it never happened to me.Pipe
To Vortex rammer system?
