Need help with wiring diagnostics (agent86...)
Anyways, I'm really begining to question my ecm. heres why...
-It keeps storing code 24, the wheels haven't moved in a while!
For the last few months, it'll pop up about once a week randomly; doesn't light the cel, speedo is working fine...somethings fishy. theres more...-I can't get my aldl to talk to my laptop. I can see everything except aldl data, and I have everything needed to do it correctly. still more...
-The car is running pig rich. I've found some problems and fixed them, hasn't changed a thing. Only way I can get the car to not run so rich is bring the tps down to a crazy low number, like .44v, and its still rich!
All these things can point to the ecm (a NAPA reman unit that has some years on it, probably 10 years old).
Anything in the fsm that tells a way to check voltage to determine a faulty ecm? Maybe if I just checked a bunch of sensors that should have 12v coming in, I'd see numbers all over the place...just don't know which wires to check without the fsm.
Thanks guys!
I do think I have discovered the issue with the newer TunerPro - on my particular laptop the serial data is coming in on COM 5. That's where both WinALDL and TunerPro v4.13 see it. TunerPro V4.14, however, doesn't "see" the cable at com 5, it "sees" it on com 3. No Data there, tho. If I ignore the "cable not found" error and set it for com 5 anyhow, the data does come up - it works.
The other option would be to forget about all of this computer software based stuff and plug in a dedicated Scan tool. No questions about That working right - either it will see the ALDL data or the ECM/ALDL/Wiring is bad somewhere...
I forget (and the Book isn't here at work..) - what is a code 24?
Thanks guys!
Cheers,
Michael
Com 3 is just what it comes set to ; each laptop could be different depending apon equipment installed.
Mine is Com 2 on the serial and Com 5 if I use the USB cable.
Code 24 is VSS; open or no activity
http://chevythunder.com/fuel%20injec...ecm%20#1226870)
No one in your area that can lend you an 85 ECM.
