Your Dash Gauges
Old Aug 19, 2008 | 03:42 PM
Sweet 90's Avatar
Sweet 90
Default Your Dash Gauges
Do your gauges (Oil Pressure, Water Temp, Oill Temp and Volts) go to zero when you shut off your car or do some stay where ever they were before you shut off the ignition? (1990 Coupe 6 speed)
My water, oil and volt gauges remain where ever they were but reset
once I turn the ignition. Is this normal??
Jim
Old Aug 19, 2008 | 03:55 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have a 1990 as well and oil pressure goes to zero but my temps stay close to where they were. I think it is normal. Mine have always done that (had the car for two years).
Old Aug 19, 2008 | 11:38 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Jim
Mine does the same.
Old Aug 20, 2008 | 10:32 AM
Sweet 90's Avatar
Sweet 90
Thanks guys, apparently something in my dash is drawing power and I thought maybe it was the gauges.
Jim
Old Aug 20, 2008 | 07:23 PM
Red Dwarf's Avatar
Red Dwarf
Jim
Does your speedometer work in reverse?
Old Aug 20, 2008 | 10:27 PM
Sweet 90's Avatar
Sweet 90
No everything works fine, but there is a drain which will kill my battery after about 3 days.
Jim
Old Aug 20, 2008 | 10:39 PM
Bad Karma's Avatar
Bad Karma
Jim
Have you tried pulling fuses one by one to see what circuit is causing the drain?
Happy hunting, I hate electrical problems.
Old Aug 21, 2008 | 07:04 AM
89er's Avatar
89er
Jim
I have the same problem on my 1990 6 speed vert. The battery goes dead in three days. During the three days it's draining the security light is usually blinking off and on. If I pull the fuse that stops the blinking the drain stops but the car won't start without it. Once in awhile the security light isn't blinking and it will go dead in four days.
Some day I would like to fix it but for now I ended up putting a battery switch on it.
http://cgi.ebay.com/ebaymotors/Side-...spagenameZWDVW
Old Aug 21, 2008 | 07:10 AM
Mekanic's Avatar
Mekanic
security light blinking?
Check the switches on the doors and hatch for the dome/security/ajar
They go bad quite often
Old Aug 21, 2008 | 10:18 AM
Sweet 90's Avatar
Sweet 90
I think I tried everything, so I finally took it in to a highly regarded Corvette shop. There is something in the dash circutry that goes bad and will drain power. They have to remove the dash to fix this. I think
it's going to quite expensive though (what isn't up here). As these guys specialize in C3/C4 Vettes he told me this can be a common problem with '90 to '96. So if any one else is chasing a short that you can't find, I will post again when I get my car back.
Jim
To Your Dash Gauges
