timing question
Old Aug 20, 2008 | 09:46 AM
heck's Avatar
heck
Default timing question
set the timing on my fresh 406 to 6 degrees base timing with ECM wire disconnected, then battery disconnect / reconnect, question is when I plug the wire back in / restart and watch the timing, what should the advance be at around 2500 RPM? I'm seeing 40 + degrees advance by the ECM, is this normal? That much sounds bad to me but there is no knock or ping, sounds fine.................any thoughts?
Old Aug 20, 2008 | 10:39 AM
1bigjim's Avatar
1bigjim
[QUOTE=I'm seeing 40 + degrees advance by the ECM, is this normal? That much sounds bad to me but there is no knock or ping, sounds fine.................any thoughts?[/QUOTE]
I am going through the exact same thing, I am seeing 38 degrees and it jumps around. Did your idle jump up when you pluged the ECM wire back up?
I have a high idle issue (1,000 out of gear) and thought it was the timing.
Old Aug 20, 2008 | 10:52 AM
heck's Avatar
heck
idle RPM increased slightly and smoothed out a bit, b I am idling around 700 - 800 RPM, just don't know why the advance goes so high when revving
Old Aug 20, 2008 | 12:26 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
It depends on whether you are running a stock or custom tune. Either way, at 2500 rpms under virtually no load, 40 degrees is probably in the ball park.
At higher rpms (3000+) and very light loads, I run over 40 degrees of total timing with no issues.
Old Aug 20, 2008 | 01:39 PM
JAKE's Avatar
JAKE
Remember, part throttle timing and WOT timing are different. At part throttle you can see OVER 40 degrees BTDC under certain conditions.
Jake
Old Aug 20, 2008 | 10:09 PM
Iroc57's Avatar
Iroc57
The computer must advance the timing similar to the weight did on old distributors. 38-40 advance at 3K was not out of the ordinary. Don't sweat it
Old Aug 20, 2008 | 11:15 PM
rodj's Avatar
rodj
Exactly , that is why you have to disconnect the EST plug while setting base timing so it is not being advanced by the ECM
Old Aug 21, 2008 | 08:21 AM
heck's Avatar
heck
Thanks guys, finished the fine tuning last night, left the timing alone thanks to your input, put the scanner on and everything looks great! no codes and in closed loop! woo hoo 406! power
Old Aug 21, 2008 | 09:13 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I am replacing the cam in my '90. This is my first cam replacement on a computer controlled car. I see you guys are talking about unpluging the ECM?? Wont it not run without it? What are you talking about more specifically?
Thanks (sorry for hijacking)
Old Aug 21, 2008 | 10:29 AM
heck's Avatar
heck
To set the base timing you must unplug the wire to the ECM, this eliminates the computer from advancing it and allows you to get a true reading.
Old Aug 21, 2008 | 11:57 AM
Kubs's Avatar
Kubs
Is this on the dist.? Which one is it?
Old Aug 21, 2008 | 06:24 PM
rodj's Avatar
rodj
Black plug on single wire (tan / blk ??? ), comes out of loom on firewall behind dist
Old Aug 21, 2008 | 06:59 PM
Sinister87's Avatar
Sinister87
If you go buy a Haynes manual it does show a picture along with the location, you should buy a manual period good to have.
To timing question
