Urathane Motor Mounts
Old Oct 11, 2010 | 05:24 AM
conv90's Avatar
conv90
...just a question .... :confused . .. the 84-91 motor mounts are on RUBBER??
Mine is a '90 and for what I saw they are solid....
Old Oct 12, 2010 | 06:44 AM
DVNCI's Avatar
DVNCI
Originally Posted by mnstrlt1
For the sake of clarification, the converation above is in regards to 84-91 mounts, right? Because from what I understand the mount design changed (so did the k-member) for 92' and newer corvettes.
Does anyone know if poly mounts are available for corvettes w/the LT-x engines (92'-96'). thanks!
correct - this will NOT work for LTX cars
Old Oct 12, 2010 | 08:06 AM
Aardwolf's Avatar
Aardwolf
Thought they are rubber, oil filled? Engine moves passenger side 1/4" on my good stock mounts.
Old Oct 13, 2010 | 05:59 PM
leadfoot2's Avatar
leadfoot2
Yes, they changed in 92 and nothing is available for the later ones. I've already been down that road. As someone pointed out the only option is a torque bar which I'm going to try (from Ingalls Engineering).
