85 A/C High Pressure Line?
Old Aug 21, 2008 | 02:07 PM
ejscarfo's Avatar
ejscarfo
Default 85 A/C High Pressure Line?
I've been troubleshooting my a/c system in my 85 since I've had some spare time and I have some questions. First, I was testing to see if the main cooling fan was working properly because it does not come on with the A/C in the MAX position. It does come on at 238 degrees though. I followed the diagnostic flowchart and pulled the fan switch on the high pressure line and the fan came on. According to the flowchart it says replace the switch. Is that correct? The a/c system in the car seems empty, I get no pressure reading at the drier or the high pressure line.
The line the fan control switch plugs into is all corroded too at the base of where the 2 switches are plugged in, I think I may have found the leak there, but I'm not sure until I test it. Anyway, I'd like to replace the line just for the hell of it, but I don't see a listing for it in any catalogue or even in my parts manual. Its illustrated, but no numbers are given. Matter of fact, I don't see a listing for the fan control switch either. Anyone have part numbers for these parts or point me to a place that does? I've looked at Ecklers, Corvette America and Corvette Central and even P&G Chevy, but nothing comes up. Something tells me they are disco'd.
Any help is appreciated.
Old Aug 21, 2008 | 03:43 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default line
you need to talk to eskimesor, he is parting out an 85 right now
Old Aug 21, 2008 | 09:02 PM
SunCr's Avatar
SunCr
The fan switch contacts open at 220 to 240 psi and when the signal voltage rises at the ECM, it grounds the Main Relay. Contacts reclose at 170 to 190 psi, the signal voltage drops back to zero, and the ECM removes ground from the Relay (as long as the Coolant Temp Signal is below 226 degrees). If there's no gas - or not enough gas - the pressure will not build to the switch's threshold for fan operation. You need to hook up a manifold gage set to see. You need to scan it to see the Coolant Temp Signal. Your ECM is obviously ok because disconnecting the harness cranks the fan on.
I wouldn't replace a perfectly good line - switch is available at NAPA or GM. It's mounted on a Schrader, and if that's leaking, it can be replaced.
Old Aug 22, 2008 | 10:14 AM
ejscarfo's Avatar
ejscarfo
Thanks for the tip. The line looks a bit rusty in between the 2 switches so I'm going to replace it, I actually found one in good shape. I'll have a gauge hooked up and see what's going on. Basically, if the system is empty, no pressure will build, so the fan won't come on, correct?
Old Aug 22, 2008 | 11:25 AM
SunCr's Avatar
SunCr
Correct
To 85 A/C High Pressure Line?
