1985 Cooling Fan Question ?
Old Aug 21, 2008 | 02:56 PM
corvettedan22's Avatar
corvettedan22
Default 1985 Cooling Fan Question ?
Took my 85 for a ride. The fan worked properly, thermostat did its job, every thing was fine.
Got home and the car was cool enough that the fan did not need to be on so i let it idle to reach a higher temperature.
The fan kicked on, to verify my suspicion I shut the car off and the fan shut off as well.
Should my fan stay on while the car is off until it reaches proper temp ?
Old Aug 21, 2008 | 03:20 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
No, ignition power is required for the relay coil.
Old Aug 21, 2008 | 03:24 PM
MK 82's Avatar
MK 82
Having the fan stay on wouldn't do much as the coolant is not circulating.
Old Aug 21, 2008 | 04:46 PM
86PACER's Avatar
86PACER
No.
To 1985 Cooling Fan Question ?
