My L98 is just off a fresh re-built bottom to top, .060 chrome moly rings. Ran real good, strong, then the third week she started smoking white -gray. Checked the plugs and just one was full of black deposit, can someone tell me what happened? :confused: :U
does it smoke at WOT and at idle or just at idle? Just one plug fouled out? Could be as troublesome as a blown head gasket or as easy as a bad valve stem seal or two. The person who assembled my heads used cheap stem seals and I had to replace them all because they were all lifting and allowing oil to seep in.
The smoke is coming from the tail pipe, I hope what you said is the pproblem, I'll pull the valve cover and find out. I did a compression check on that cylinder when the engine was cold, it read 145 psi. then squirted oil in there and the pressure read 165, any thoughts?
145 is respectable, the reason oil bumped it up is becuase it reduced friction on the rings. If you were down around 115 then I would say you had a ring problem but 145 is ok in my book. I hope its an easy fix for ya.
I didn't check the other cylinders for compression, I did change the valve stem seal thought the other one didn't look to bad. With it being so cold I won't be able to try it yet.
Valve guide seals keep oil out of the cylinders. Oil burns BLUE. Oil will cause a wet, slippery, black, spark plug. Gasoline leaves plugs with a comparitively dry, fluffy, black, deposit and rarely do you gas foul only ONE plug. My '84 with 140,000 miles has 165-175 lbs of compression. 165 is fine for a new engine, especially if the rings haven't full seated, yet. All cylinders should be within 10 % of each other in comp pressure. The jump from 145# dry, to 165# wet, indicates a ring sealing problem...but white smoke indicates WATER. Antifreeze can leave plugs black. A .060 overbore is marginal on some late model sbc castings. To me, the prime suspect is a cracked leaking cylinder wall. I hope I'm wrong, but that is the best guess I come up with based on the information you've provided. In any case, I'm convinced that it is water that is causing your white smoke. I hope it IS a gasket. Good luck.
