Engine Vibrations - Low RPM
Old Jan 2, 2002 | 10:15 PM
micropro_wright's Avatar
micropro_wright
Default Engine Vibrations - Low RPM
Well I am a new Vett owner, after many years of wanting one !!!
Should have done this YEARS ago..
I purchased a 92 Conv, 6-speed with 99K miles on it and love it !! One question now, I have put 7K miles on it and a low RPM (1200) vibration shows up much of the time when the motor is cold for 10-15 miles. It is motor speed dependent, not car speed.
I suspect the "dual-mass" flywheel, but then I think a 100K/10 year old car could also have a harmonic balancer that would feel the same. As it is directly motor RPM, I have ruled out u-joints.
I have read that some Porsche models have had this problem with the "dual mass" flywheel, which is why I suspect the wheel. Any ideas would be greatly appreciated
Larry Wright
Carson City, Nevada
Old Jan 2, 2002 | 10:26 PM
BobMachus's Avatar
BobMachus
Default Re: Engine Vibrations - Low RPM (micropro_wright)
Is it exhaust resonance? Mine has a resonance point at 1k and 1.3k with 1.3k being worse by far.
Old Jan 3, 2002 | 01:11 AM
vader86's Avatar
vader86
i believe you do have a harmonic balancer that goes bad sometimes. ive heard this problem before.
[Modified by vader86, 5:12 AM 1/3/2002]
Old Jan 3, 2002 | 12:54 PM
micropro_wright
Default Re: Engine Vibrations - Low RPM (BobMachus)
Thanks for input, but nope not a noise, but a vibration I can lightly feel in the gas pedel & shifter.
Larry Wright
92 Red Conv
Old Jan 3, 2002 | 12:57 PM
micropro_wright
Default Re: Engine Vibrations - Low RPM (vader86)
Thanks for the harmonic balancer input. I guess since they do have a rubber component, that would help explane why it goes away after 15-20 minutes when the temperature effects the rubber consistancy.
To Engine Vibrations - Low RPM
