Something weird happened w/ my C4?
Old Aug 23, 2008 | 08:28 PM
Rob10R's Avatar
Rob10R
Default Something weird happened w/ my C4?
Well I took my C4 to work yesterday she ran like a champ like always until I went home after work...Pulled into the driveway, had to back up a lil to straighten her out to pull in the Garage...as I started to pull in heavy jerking started happening it was some crazy sXXt!! I turned her off fast..nothing leaking everything fine under hood, under car..I had her for bout a year and no problems..I'm going to look thru the history maintenance stuff to see if the Opti has been replaced and other things before...Also I haven't messed with her yet and yes SES been blinking lately..I do have an Autoxray w/ OBD I and II but had to order couple of days ago a specific connector for my vette..So what do you guys think? kinda scared to try turning the key...
1995 C4
Old Aug 23, 2008 | 08:31 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Year?
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Aug 23, 2008 | 10:05 PM
Eddie & the Cruisers's Avatar
Are you misssing a cat?
Old Aug 24, 2008 | 12:47 AM
Rob10R's Avatar
Rob10R
Well I've installed 2 weeks ago Chamberred pipes with muffler eliminators to the factory headers and cats... Prior to the install on drivers side I had a lil problem getting 1 of the nuts off of the studs on the cat pipe...Rusted s**t as hell lots of WD40..I tried taking the whole driver cat off of the header and managed to loosen 2 nuts but broke off 1 nut w/ a stud that came of the header!!... so after I got everything put together theres only 2 studs and 2 nuts holding the driver side header with the cat...would that cause that weird acting up??...Pretty soon I'm gonna order some hooker shorties to replace those factory Headers... Also I 've checked both cats and they looked ok...
Old Aug 24, 2008 | 09:03 AM
vette079's Avatar
vette079
Is it possible to pull codes on a ´95 with paperclip?
Could be an O2-sensor giving false info to ECM when you have a leak in the exhaust (backpressure-issue).
Old Aug 24, 2008 | 11:26 AM
Redeasysport
I gave him the link to do it and am waiting for his results.
Old Aug 24, 2008 | 03:35 PM
Rob10R's Avatar
Rob10R
Hey guys I haven't been able to get around to figure what code its throwing yet...tried to do that pin code thing its a lil pain climbin under the steering to look at the connector closely..I'd try again..wish I had that OBD II Connector ...oh one more thing its blinking "SYS" not SES actually..
Old Aug 24, 2008 | 05:41 PM
Redeasysport
SYS is usually a bad battery.
Old Aug 24, 2008 | 11:37 PM
Rob10R's Avatar
Rob10R
well, well, I cranked her up and looked under the hood..sounded like it was missing, loping smelled a lil rich..drivers side looked good..than got to the passengers side looked around and boom I see something sparking! one of the freaking sparkplug wires was touching the manifold!! took it of the manifold and back to normal:thumbsup: ...jeez a wire touching a manifold cause this weird mystery...thanks all for the help!!!! the battery is still brand new bought it last year..thinking maybe the new aftermarket radio throwing that SYS light once in a while??
I'm thinking of getting some new ignition wires what do you recommend to replace the factory 7mm wires??...been looking at 8.5 mm MSD wires...thanks ya!!
Old Aug 24, 2008 | 11:42 PM
Camaro350z28's Avatar
Camaro350z28
it was only touching and not burnt? and was still arcing? id think about some new wires
Old Aug 24, 2008 | 11:53 PM
Rob10R's Avatar
Rob10R
yeh..it was only touching not really burnt..put some electric tape over the touched area...good to go...cant believe something like that could cause the car act up..Also I have decided to go with the
8mm Granatelli Spark Plug Wires... thanks again ya
Old Aug 26, 2008 | 09:48 PM
Redeasysport
Yep that is what is tripping the SYS light good find on the wire. There is a fix for the aftermarket stereo SYS light trip might want to try some searches or check the tech tips. I have seen it posted around here before.
Old Aug 27, 2008 | 04:50 AM
vette079's Avatar
vette079
Saw it now. Time for me to wake up I guess
To Something weird happened w/ my C4?
