Rear Lower Shock mount bracket
Old Aug 24, 2008 | 04:04 PM
LD85's Avatar
LD85
Default Rear Lower Shock mount bracket
I decided to go ahead and buy the bracket seen in the picture in the middle pic, the one with the 2-1/4" measurement from the mount face to the hole Center line (CL)
The 2-1/4" dimension is what I need to allow clearance between the QA1 coil OD and the knuckle area.
They are going to put one single 16mm hole in the mount plate instead of the 2 holes seen in the pic. Then all you would do is put a bolt thru the hole and knuckle and you are good to go, since it is steel I will maybe powder coat it or just prime it well and paint it.
On the shock mount bolt, I will buy a shoulder bolt and run it thru the holes so that the threads are not resting on the ID of the thru hole
