FX3 shock conversion
Old Jan 3, 2002 | 10:31 AM
jdeflurin's Avatar
jdeflurin
2nd Gear
Default FX3 shock conversion
I have a 93 vette that had the FX3 shock system on it when I bought the car (sadly,the car was not well maintained). The problem is that they are all shot and I can not afford the $800-1200 to replace them. I drive the car daily and would like to replace the FX3 system with a good set of regular shocks. Do I need a kit or are there shocks that will fit.
Old Jan 3, 2002 | 11:16 AM
NeedSpeed's Avatar
NeedSpeed
Default Re: FX3 shock conversion (jdeflurin)
Bilstein can rebuild them for less. Someone should chime in with the info to do that. I can't remember how much, but I know it wasn't that bad.
Old Jan 3, 2002 | 11:41 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
I'm selling my FX3 shocks if you're interested. They all work, the only reason I'm removing them is to go with coilovers. $400 for all 4.
Email me at evan@LT1.net if you're intersted.
Old Jan 10, 2002 | 08:53 PM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
Several months ago there was an article in the Wear and Tear section of Corvette Fever that addressed the conversion of FX3 to regular shocks. The process was not that involved and required disconnecting a small module, I think behind the driver's seat. If you are interested, I will locate the article and fax it to you. Just Email me with your fax number and mention the article in your note.
SAVE THE WAVE
Old Jan 10, 2002 | 09:08 PM
c4cruiser's Avatar
c4cruiser
You can contact Bilstein through their website at http://www.bilstein.com
They can rebuild you shocks either to the OEM specs or they can be custom-valved for your own driving style or needs. I thing the cost is around $75 or so per shock. The FX3 system is a very good system; it IS expensive to replace the actuators but IMHO the money is well worth it.
You can disconnect the shock controller behind the driver's seat and under the lid. Remove the Bilstein shocks and the actuators and replace with something else. Some folks use KYB Gas-A-Just as a good shock replacement. Just ask for shocks for your car as though it did not have the FX3.
By all means keep the Bilstein shocks and maybe you can save some bucks to get them rebuilt later on.
Old Jan 11, 2002 | 09:44 AM
jdeflurin's Avatar
jdeflurin
2nd Gear
Default Re: FX3 shock conversion (c4cruiser)
Your input has been most helpful. I think that I will keep the FX3 shocks to repair later. Thanks for taking the time.
Old Jan 11, 2002 | 11:57 PM
importeater's Avatar
importeater
i also had a fx3 car & sold the shot shocks and actuators for 300 to buy a set of new z51 bilsteins. car is MUCH better now but i almost wish i would have just spent the cash & had mine rebuilt, oh well since i just left it in performance all the time i'm not sure if i'd even notice a difference. if you really want a tight shock try the konis.
To FX3 shock conversion
