Blow-through singleplane / LS1 throttle body
Old Sep 8, 2008 | 07:42 PM
anesthes's Avatar
anesthes
Originally Posted by TJM
Joe, how much clearance will you have between the top of the manifold [as machined] and the hood?
I am thinking about the practicality of a twin screw?
TJM
Well the hood slopes down, so figure where the front carb bolts are you have about 5" total, in the rear closer to 6.. Much past the front bolts and you have 4-3..
If you didn't have a distributor, you could run one of those EFI screw blowers.
-- Joe
Old Sep 12, 2008 | 10:28 PM
anesthes's Avatar
anesthes
Elbow is done. Gonna fire it up tomorrow.
Old Sep 13, 2008 | 03:33 PM
anesthes's Avatar
anesthes
Runs good. Just need to bolt down the throttle-cable bracket.
Old Sep 15, 2008 | 11:41 AM
john@ATI's Avatar
john@ATI
2nd Gear
i have been gone from the forum for some while now but back again and you will love this intake i made 888hp with a d1 and a fast set up. i didnt mind that mine went thru the hood. i used a wilson elbow and a 95 mm t.body i will see if i still have some pixs from whrn the car was at carlisle a few years back it was lime green. good luck with your project
Old Sep 16, 2008 | 08:02 AM
anesthes's Avatar
anesthes
Well connecting the PVC to the same feed as the brake booster was a stupid idea..
I'll fix that today. I have to redo my fuel maps. ve is way off. Idle is ok, part throttle is stupid rich.
-- Joe
