Before and after injectors
I'm glad the car is running better, but I miss the great milage. I just don't get the 30% drop.
The first time I put Bosch III's in mine, I forgot to do this; it ran terribly and I lost major mpg. The computer still says I'm about 3mpg lower than I was before them, but I figure the ECM is still on it's learning curve, plus the computer might not work perfectly with the different injectors.
What do you mean by "closed loop"? Maybe I need to go through the process again?
good combustion with a stoich air/ fuel ratio will pulse the amount of fuel needed to keep that ratio. Normally 14.7 to 1. However, in open loop on a hot engine the A/F ratio can be 12 to 1. Running rich all the time= poor mileage. A scan with datalogging will tell you by the BLM s how much the ECU is correcting the injectors.
If your cars are running in open loop, the o2 sensor is cold. plain and simple. my car runs rich, but the BLM's are way high. but it runs amazingly good. I'd never know if I didn't smell the rotten exhaust.
I thought the computer always learns. long term and short term fuel trims is a continual closed loop feed back system. The MAF cars are suppose to be pretty flexible.
I'm glad it's a bunch of us having these problems. we have to figure this out. mine is a MAF TPI motor with single wire o2 sensor.
I can reset the ECM 1 more time, but I don;t see that making a difference. it's something with the 02 sensor. maybe the 10% ethonal in the fuel is making the exhaust gases cooler???
I tried 19's, car run great, except at WOT where it leans out too much, and stumbles.
then I tried 21's, and it's pig rich at idle, but BLM's way too high anyway (150+). but it runs great through out the RPM range.
either the o2 sensor is not reading correctly to compensate, or something. but the car is just not right with the stock PROM, and newer injectors. It feels great, but if you watch the BLM's, something is screwy.
my car is just dumping fuel at idle, cell 0, and the BLM's are 150+. exhaust stinks rich, and the computer is not compensating correctly. then it sometimes jumps back to open loop because I think the o2 cools off.
your the first person who has mentioned this. and I have been thinking about this. and all these people losing fuel mileage, but their car runs too good to notice. I only notice this because I have an auto xray, and drive around with it.
