Grounds
Old Aug 26, 2008 | 08:37 PM
killeffer's Avatar
killeffer
5th Gear
Default Grounds
Where are the grounds on an '86 coupe? I've found the one on the left door frame, but I read in one of the 'Vette magazines that there may be nine or more additional grounds.
Old Aug 26, 2008 | 09:49 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I know of nine. Which one are you looking for, or what circuit is giving you a ground problem ??
Old Aug 27, 2008 | 11:33 AM
killeffer's Avatar
killeffer
5th Gear
Default Grounds?
My car has problems with the Heat/AC blower and "Digititis" of the dash. I would really like to find all the electrical ground points and be sure each thing that is attached to them is well grounded. All the problems I have are intermittent. This suggests that poor electrical connections may be responsible.
Any help will be greatly appreciated. I have owned this vehicle for seven years. It was sold new in a small town about 90 miles from here. There have been one or two other owners. I don't know who they were or if they had any problems with the car. Current odometer reading is 80K and this squares with the clean Carfax report (69K) when I bought the car.
Old Aug 28, 2008 | 10:19 AM
AGENT 86's Avatar
AGENT 86
G101-near RH side of battery, on frame.
G104-on block, above oil filter
G115-on frame, behind LH park/turn lamp
G116-on frame, behind RH park/turn lamp
G117-LH side of engine compartment, on front cross member
G125-behind RH kick panel
G201-behind I/P, near LH side of steering column
G320-LH B pillar
G400-on frame, above LH rear wheel
G401-base of RH B pillar
http://members.shaw.ca/agent86/Instr...%20Cluster.pdf
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
To Grounds
