Air Temperature Sensor....What the?
Old Aug 27, 2008 | 05:27 PM
mcfack's Avatar
mcfack
Default Air Temperature Sensor....What the?
Okay, I have an 89 car with an 85 plenum. When I unscrewed what should be an air flow sensor from the underside of the plenum, it appeared to be a coolant sensor (metal probe). Come to find out that the local dealer and NAPA store offered me the same sensor I have when I went to try and purchase the one with the plastic probe. Mid America shows the two sensors and the plastic probe is only for hte 85 model.
Can anyone out there verify (1) that I should use the one I have which is the metal probe and (2) should I purchase the plastic probe since I have an 85 plenum?
I am leaning towards just using what I have because I have no sign of a code being thrown due to failure.
Old Aug 27, 2008 | 08:12 PM
joeld's Avatar
joeld
I would stay with the 89 sensor, since the ECM and the car is a 89. Using a different plenum shouldn't make any difference. I assume threads are the same?
Joel
Old Aug 27, 2008 | 10:19 PM
Benny42's Avatar
Benny42
The sensor resistance curves are the same. The metal sensor may be
slightly slower to respond, but my '89Formula has that type of sensor
and did when i got it. I don't datalog, but the car runs fine. I noticed
it when i pulled the plenum to replace the EGR valve. benny
Old Aug 28, 2008 | 01:26 PM
black85's Avatar
black85
I used the later style sensor in my '85, I left the original in the plenum to fill the hole, then bought one of those relocation kits and put the new sensor in the "power coupler". That is the hose they sell to replace the accordion tube. I have since been told that this is a complete waste of money for an '85 because it supposedly doesn't change anything by moving it to the cooler location. It is supposed to help in later cars, but I don't know what the cut off is, and really don't remember the details. It was probably 6 yrs ago on this forum that I read this.
I don't know if it helped, but my car runs pretty good for the little things I have on it.
Old Aug 28, 2008 | 08:41 PM
mcfack's Avatar
mcfack
Thanks for the posts, vette brothas.
Old Aug 29, 2008 | 08:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The sensor is part of EGR control, it serves no other purpose. I concur that it is a waste of money to move it.
Old Aug 29, 2008 | 08:37 PM
mcfack's Avatar
mcfack
Hahahahaha, I have removed all EGR equipment. Sweet! Thanks.
To Air Temperature Sensor....What the?
