Upgrading single piston calipers...
Old Jan 3, 2002 | 08:03 PM
BBA's Avatar
BBA
Default Upgrading single piston calipers...
Ok, I really don't care about the GS upgrade, but I would like to upgrade my crummy single piston calipers as cheaply as possible.
I noticed here:
http://forums.corvetteforum.com/zerothread?id=211698
Where GS upgrades are discussed, has info on the two piston calipers for the 12" rotor. I am thinking since my car has 12" rotors, can I simply replace the single piston calipers with the two piston calipers for 12" rotors?
I was also thinking that I could replace my rear calipers with the same.My parking brake should not be a concern, since it's nothing more than a mini-drum brake inside the rotors hub, I could use the two piston front caliper in place of the single piston rear I have now...right?
What brackets would be needed?
[Modified by BBA, 7:04 PM 1/3/2002]
Old Jan 4, 2002 | 12:21 AM
snaketr's Avatar
snaketr
Default Re: Upgrading single piston calipers... (BBA)
What year is your car? Assuming because you said you had drum emergeny brakes it is a 84-87. The only problem with your thought is that you front spindle supports won't work. You would have to make a bracket that could bolt to your spindle supports and then to an 88-94 12" caliper bracket. As far as the rear, A.O. Engineering sells a rear bracket that will mount two calipers. They use the stock rear calipers but it mounts two of them. A.O. Engineering does not sell straight to the consumer so you will have to find a dealer that sells there products. As far as the front as long as you make your own bracket, which you said you can fabricate anything, a stock 88-94brake caliper bracket and caliper will bolt right on. You will notice a big difference in this.
Old Jan 4, 2002 | 06:58 PM
BBA's Avatar
BBA
Default Re: Upgrading single piston calipers... (snaketr)
I was thinking I would notice a big difference. All I have to do is get the calipers, make the adapters and bolt them on. I can probably make adapters from scrap metal at my neighbors machine shop.
Anyone got any calipers they don't want? I can't afford much but I can pay shipping. :)
Old Jan 4, 2002 | 07:04 PM
John Row's Avatar
John Row
I've got a set of calipers, rotors (about 5K miles), brackets from my 94 you can have for shipping costs (all or any piece). I just did the GS upgrade about a month ago.
Old Jan 5, 2002 | 12:13 AM
snaketr's Avatar
snaketr
Default Re: Upgrading single piston calipers... (John Row)
Do you still have the Fluidampr?
Old Jan 5, 2002 | 07:16 AM
johndezman's Avatar
johndezman
John Row if BBA isn't interested in that offer contact me, i am.
respond to johndezman@hotmail.com
Old Jan 5, 2002 | 07:18 AM
johndezman's Avatar
johndezman
John Row, if BBA isn't interested in your offer, i am. be happy to send shipping $$$.
contact me at johndezman@hotmail.com
Old Jan 6, 2002 | 08:22 PM
BBA's Avatar
BBA
John...yes, I will be more than happy to pay you to ship them.
Old Jan 6, 2002 | 08:23 PM
BBA's Avatar
BBA
snaketr...Yes, I still have the Fluidamper. What do you propose?
Old Jan 6, 2002 | 08:49 PM
okinawa86vette's Avatar
okinawa86vette
Check out this link, it might be helpful for everyone wanting to upgrade their C4's brakes. It's an online article from Corvette Magazine. http://www.corvettemagazine.com/2001...ade/brake1.ASP
Chris
Old Jan 6, 2002 | 11:54 PM
snaketr's Avatar
snaketr
I have complete set of front calipers and brackets for an 88-94 with 12" rotors. Remind me was the fuidamper for a 350 or 400?
Old Jan 7, 2002 | 12:03 AM
BBA's Avatar
BBA
400, It's a two piece external balance SFI unit, I had it on my last 383.
( It wasn't cheap when I bought it...over $300. )
Old Jan 7, 2002 | 12:06 AM
snaketr's Avatar
snaketr
If you want I will swap you, but it sounds like you already have another deal going.
Old Jan 7, 2002 | 12:12 AM
BBA's Avatar
BBA
Well...I need all four, I want to do the front and back calipers, so with yours I will only have to make the adapters to mate them to my rear housing.
It's a deal...send me some details...
bhunter@mediaone.net
Old Jan 7, 2002 | 12:32 AM
snaketr's Avatar
snaketr
Do you need rear or front?
Old Jan 7, 2002 | 02:42 PM
BBA's Avatar
BBA
Snaketr...I want 4 front calipers. I am intending on putting two piston calipers on all four corners of my car.
If I can get the set from John ( above ) and the other two from you, I can do all four. I know I will have to make the brackets for the rear calipers and hopefully the brackets John has with his fronts will work for the front of my car.
[Modified by BBA, 5:19 PM 1/7/2002]
Old Jan 7, 2002 | 03:19 PM
John Row's Avatar
John Row
You've got mail.
Old Jan 7, 2002 | 04:16 PM
snaketr's Avatar
snaketr
BBA I will e-mail you tonight or you can e-mail me. I need your address to ship them too.
Old Jan 7, 2002 | 06:38 PM
BBA's Avatar
BBA
John and Justin....You have mail. :cheers:
To Upgrading single piston calipers...
