[4+3]: Return spring for shifter button.
Old Jan 3, 2002 | 08:38 PM
scorp508's Avatar
scorp508
Default [4+3]: Return spring for shifter button.
Anybody know who made the spring? :) It isn't a big emergency or anything. Mine has aged and isn't as springy as it probably was originally. In fact the bottom about 4/5 coils were all twisted up so I had to snip them off and pack some paper into the hole to make up for the lost length.
I wonder if a spring from a retractable pen will work. :) I'll figure something out.
Old Jan 3, 2002 | 09:09 PM
Rich B.'s Avatar
Rich B.
Default Re: [4+3]: Return spring for shifter button. (scorp508)
...Ummmm...I know you must have already researched this...But is there any reason you can't order part # 00371757 "SPRING" from GM???
Jeff was able to send me one a couple months ago...
But, if you'd like to match one up at your hardware store, I could probably measure this one... :yesnod:
Old Jan 3, 2002 | 09:14 PM
scorp508's Avatar
scorp508
Default Re: [4+3]: Return spring for shifter button. (Rich B.)
LOL. No, I hadn't looked it up. Jeff told me a few months ago the only things left were the shift pattern button and the switch, so I never bothered. :D
Lemme go put my dunce cap on...... :crazy:
Old Jan 3, 2002 | 09:26 PM
Rich B.'s Avatar
Rich B.
No, wait...I see in my book there's *two*springs...One is under the nylon block down near the switch p/n 14101389; the other is under the **** and holds the reverse rod down...That second one is the number I gave you...
My 4+3 didn't have any spring under the nylon block; the switch has its own internal spring, and was good enough for my useage...
Sorry for any misinfo!!! :bb
Old Jan 3, 2002 | 09:32 PM
scorp508's Avatar
scorp508
No problemo. :)
Old Jan 3, 2002 | 09:53 PM
Rich B.'s Avatar
Rich B.
Default Re: (scorp508)
No problemo. :)
...But the bad news is: Looking through my emails, Jeff told me the little one under the nylon block has been discontinued... :(
Old Jan 3, 2002 | 09:58 PM
scorp508's Avatar
scorp508
Default Re: (Rich B.)
Back to my pen collection! :D
Old Jan 3, 2002 | 11:34 PM
Romeo Barrera's Avatar
Romeo Barrera
If you take the spring down to your hardware store I bet they'll have something very similar.
Old Jan 4, 2002 | 10:30 AM
Rich B.'s Avatar
Rich B.
Default Re: [4+3]: Return spring for shifter button. (Romeo Barrera)
Romeo -
Mine never had one of these springs. Can you measure length, wire dia, # of coils, outside dia of spring, and post it back to us???
I'm not too concerned, but I know someone with dreams of a NTSC award who lacks one as well... :D
Old Jan 4, 2002 | 11:53 PM
Romeo Barrera
Romeo -
Sure, while I'm at it I'll give ya my first-born :p: j/k I'll try and look at it this weekend. I imagine that previous owners may have dropped this spring into the shaft, accidently forgetting that it goes on top of the reverse lockout lever. Don't ask me how I know this, luckily I had the side panel off to adjust my shifter :) Take your **** off and look down inside the shaft. If this is the case, you should be able to retrieve it with a coat hanger with a small fishook bend in it.
Old Jan 5, 2002 | 07:22 AM
Rich B.'s Avatar
Rich B.
If she can clean house, I'll take her! :D
My side cover & seat are out; all top panels off, too. My shifter is out being inspected & lubricated. My tunnel had broken parts, matches, and cigarettes...but no springs...
...accidently forgetting that it goes on top of the reverse lockout lever.
Ah, that's not the spring Scorp wants. That one is the number I first posted above - 00371757. That's still available. The other one is *possibly* between the nylon block (slider) and the switch. It's number 42 in the parts book - part # 14101389.
It may not be part of the '86 - '88 Vettes with the switch in the stalk. The parts diagram shows an '84 - '85 console with the switch in the console. The spring is shown in the location where the '86 - '88 switch fits. The '86 switch has a spring in it; GM may have decided that was adequate. (My conjecture).
[Modified by Rich B., 6:37 AM 1/5/2002]
To [4+3]: Return spring for shifter button.
