QA1 Shock problems? Anyone?
Old Aug 30, 2008 | 03:19 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default QA1 Shock problems? Anyone?
Well I basically rebuilt the suspenion a few months ago, then the engine right after.
I forgot about the QA1's last settings. So today I decided to check them out as I just put over a 100 miles on the engine and suspension.
Well, my QA1's have about 16 settings up front. I must have a special set of them. I know they are supposed to be 12 settings, but they keot on turning to 16. The rears did 13. Interesting.
I have to look at the dial and see if the little screw unseated and backed out. But it doesn concern me as to why these shocks did this.
I know they arent Bilsteins/Penskes etc etc, but for the price they shouldnt do this.
Has anyone else had problems with theirs?
Old Aug 30, 2008 | 04:51 AM
pablocruise's Avatar
pablocruise
The seal blew out on the passenger side rear at the dragstrip.
It was a new QA-1.
I sent it in and they(summit) replaced it right away.
Old Aug 30, 2008 | 05:52 AM
steve40th's Avatar
steve40th
I need to se when I bought them
Old Aug 30, 2008 | 08:40 AM
StealthLT4's Avatar
StealthLT4
Never had any problems with mine...strange
Old Aug 30, 2008 | 09:02 AM
Road Agent's Avatar
Road Agent
Same here!
Old Aug 30, 2008 | 10:53 AM
LD85's Avatar
LD85
I recall the directions saying to not turn more than 3 clicks past the 12th position.
Old Aug 30, 2008 | 11:49 AM
Bobwhite85's Avatar
Bobwhite85
I have a set that I bought used from a Forum member 3mo ago that has 15-16 settings. I have them set on 7 and they work good almost to good, thinking of turning them down 1-2 knotches.
Old Aug 30, 2008 | 12:45 PM
Mo_Bandy's Avatar
Mo_Bandy
I've run mine for over 5 years now NEVER an issue.
MO
Old Aug 30, 2008 | 03:04 PM
steve40th's Avatar
steve40th
I am a sailor, they need to stop at 12
I will back them up to 1 and move forward. I havent driven them like this, as 7/8 was where they were set originally if I remember correctly.
Old Aug 30, 2008 | 03:58 PM
LD85's Avatar
LD85
I will back them up to 1 and move forward. I haven't driven them like this, as 7/8 was where they were set originally if I remember correctly.
Just got QA1 my directions out so here is what it says, verbatim;
" QA1 shocks have 12 dampening positions. There are 4 clicks per revolution of the ****, The **** has 3 complete revolutions, The **** set fully counter clockwise is the softest setting-start your adjusting from that point. Do not adjust pass the 12th click, or 3-revolutions from the softest setting.
NOTE: Do not force the adjuster ****, Do not use pliers or other tools on the adjuster ****. Do not exceed 12 clicks under any circumstances. This could damage the idler pin and cause the shock not to adjust, this will avoid all warranties. "
Old Aug 30, 2008 | 04:31 PM
steve40th's Avatar
steve40th
Thanks, I guess I didnt read that part .
Oh well, they are fine, as I didnt drive them.
Old Aug 31, 2008 | 09:21 AM
89FX3's Avatar
89FX3
I am a sailor, they need to stop at 12 ...
Reminds me of the bit in Spinal Tap about turning the amp up to 12...
Frogive me for not understanding the Navy Puke reference though; I was a USAF Flyboy Puke.
Everything in the cockpit stopped at 10.
Subs must be different.
I'll ask Noland to 'splain it to me.
Old Aug 31, 2008 | 11:29 AM
steve40th's Avatar
steve40th
Noland and I are bot STS's (Sonar Technician Submarine), but I am sure he can explain it well.
To QA1 Shock problems? Anyone?
