AFR Hydra Rev Kit
Old Aug 30, 2008 | 07:54 PM
MK 82's Avatar
MK 82
Default AFR Hydra Rev Kit
I was reading on the AFR site about the 195 Eliminators. They suggest the use of the Hydra Rev Kit if you are going to spin above 6000.
I had never heard of this kit.
Anyone have any experience with it?
Old Aug 30, 2008 | 08:13 PM
rklessdriver's Avatar
rklessdriver
Yes. I have one on my personal engine and have built a few other high RPM hyd rollers using them (the AFR specifically).
Rev Kits in general are used to keep the lifters in more precise contact with the cam lobes. They do this by using small springs which "pre load" the lifter. People have the mis-conception that the spring pressure will wear the roller brgs out faster in a roller lifter but in reality the oposite is true. Because the wheel tracks more accuratley on the lobe the lifters wheel dosen't skid on the cam lobe (espc bad on the closing side of aggressive lobes) and the lifters life is greatly extended.
It's not a free ride thou. Sice the lifters are pre loaded by spring pressure the added friction they create eats a little HP. How much depends on how much you make.
Ed Iskenderian was the biggest fan of rev kits that ever was. He stated his testing indicated that they increased the life of roller lifters by about 50%. Back in the 80's we always ran them on our oval track motors and we never had a lifter failure while others did. If I build a mech roller SBC or BBC for the street it gets a Rev Kit.
Will
Old Aug 30, 2008 | 08:21 PM
Ryan59's Avatar
Ryan59
Rev kits have been around for many years. A rev kit consists of springs to keep the lifters in contact with the cam lobe. It's basically coil springs that fit between the lifter body and the underside of the cylinder head. Every manufacturer uses a slightly different design, springs and hardware. They all do the same thing. A side benefit of them is, if a pushrod comes off, it prevents the lifter from coming out and an instant loss of oil pressure.
Another question was asked about if the side plate is retained. Yes it must be. The side plate prevents the lifter from turning sideways. A rev kit takes the weight of the lifter off the valve train as it launches upwards.
Old Aug 30, 2008 | 09:20 PM
1989TransAm's Avatar
1989TransAm
The above two posters are correct. I plan on using the AFR kit on my new L98 build up. I want the capability to be able to rev to 7000rpm's with no problems.
Old Aug 30, 2008 | 09:51 PM
5abivt's Avatar
5abivt
Does Nascar use Rev kits ?
Old Aug 30, 2008 | 09:54 PM
MK 82's Avatar
MK 82
The cool thing about them is that they place their force on the body of the lifter and not the plunger.
I think I will include the AFR kit on my LT4 upgrade.
Old Aug 31, 2008 | 09:07 AM
89FX3's Avatar
89FX3
Originally Posted by Ryan59
Rev kits have been around for many years...
True but the AFR Hydra-Rev kit is unique since it places a (slight) force on the side of the lifter.
I'd still like to know more about its longevity.
I'm the type of guy who thinks iridium plugs are GREAT since you [theoretically] don't have to replace them as frequently as non- iridiums.
In the "less filling/ tastes great" debate on this forum I guess this makes me a "less filling" guy in a land "tastes great" crazies.
The less time spent under the hood the better.
Old Aug 31, 2008 | 10:48 AM
rklessdriver
No. Sprint Nextel Cup motors are required to use flat tappet solid lifter cams.
Will
Old Aug 31, 2008 | 10:10 PM
No Go's Avatar
No Go
I'm running one.
I have 20,000 miles on it (not all easy) with no issues.
I changed from a supposedly suitable dual spring package (CNC Cylinder Heads Stage III setup) to a set of CC 918 beehives and the AFR HydraRev kit when the dual spring package was getting a 6200 rpm peak and valve float there after.
Now I shift at 7000 rpm.
Cam is a GM847 (296/304, .575/.595).
Was it the beehives or the hydra rev...probably both or atleast one is backing up the other. Dyno time was too expensive to piecemeal the install.
Old Sep 1, 2008 | 10:36 AM
MK 82's Avatar
MK 82
Spoke with Tony@AFR via PM. He thinks that with the upgrade to AFR springs #8019 I won't need the rev kit with the AFR 195 Eliminator heads.
Old Sep 1, 2008 | 11:17 AM
Vette Threat's Avatar
Vette Threat
Don't the Comp Port (1039) come with #8019s already?
http://www.airflowresearch.com/195sbc_lt4.php
To AFR Hydra Rev Kit
