Coilovers installation - pics inside
Old Aug 31, 2008 | 10:29 AM
Sliding's Avatar
Sliding
Default Coilovers installation - pics inside
I've finally decided to install front coilovers that I've bought from
CF member INSANITY a long time ago.
Taking stock suspension apart was really easy. Pulling out stock spring
is kind of tricky, but most important thing is to lift the car high enough.
Here are a few pics:
After some cleaning, one side is finished.
Front upper coilover mounts that I received with coilovers
are some some custom made metal pieces and aren't quality
pieces so I'll have my own fabricated.
I've checked on ghofmann's web page (hardbarUSA) but $85
a piece is a little bit too much for me.
So I designed my own with dimensions that I measured directly
on my car. They should be finished soon, but until then,
I'll try everything out with mounts that I received.
Mounts that I received with coilovers:
New mounts:
Old Aug 31, 2008 | 10:59 AM
rklessdriver's Avatar
rklessdriver
Actually that mount is a common one made by Coleman or UB machine for use on oval track race cars. There are litterly millions of them running on dirt and asphalt short tracks across the USA every weekend. If your worried about the quality, in a word don't.
I've never broke one or seem one break. I used the same mount when I converted my Jeep Cherokee over to coilover suspension and its survived 3 yrs (so far) of hwy driving, general off road use, rock crawling and mudbogging.
Will
Old Aug 31, 2008 | 11:53 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default shock mounts
Are those upper shock mounts strong enough to:
A. support the car on some heavy bumps without metal fatigue and distortion?
B. live a long life with negative and positive tweaking all the while supporting a car throughout the jolts of consistently rough roads?
2. is there a beef-up that anyone makes to weld onto the shock mount?
3. will you need to address the sway bar brackets close proximity to the spring?
I am interested in softening the road impacts on my 86, and am wondering how the leaf spring compares with the coil-overs.
I know the spring friction on the lower control arms contribute to the ride harshness.
Old Aug 31, 2008 | 12:00 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I'd turn that upper mount 90 degrees
And why did you remove the swaybars.
Old Aug 31, 2008 | 12:47 PM
LD85's Avatar
LD85
Nice job!
Here is another option, this is where I am getting my rear lower mount, they are making them for me with one 16-mm hole in the middle of the 2-1/4" bracket
http://rearendkits.com
Old Aug 31, 2008 | 01:08 PM
Sliding's Avatar
Sliding
Turning it 90 degrees makes it too wide. Not the mount itself, but
tightening bolt is too wide.
Swaybar is removed only temporary because coilovers won't fit stock
swaybar mounts. I've allready bought heim joints, I just need
to fabricate some threaded links for new mounts.
coupeguy2001, I did think about that upper mounts. I did a lot of
research, and it looks like only reported problems are with rear
lower mounts.
But if it'll be necessary, I'll make some reinforcements.
Originally Posted by LD85
Nice job!
Thank you LD85.
Thanks for that info, by the looks of it, I wouldn't tell that.
Old Aug 31, 2008 | 01:44 PM
Blown_c4's Avatar
Blown_c4
Nice job!
Nice!
what is your spring rate?? all 4 has the same rate, or rear is different?
what is the best for cornering and drag race setup?
i mean going to stiffer without lossing cornering performance!
Old Aug 31, 2008 | 01:51 PM
Blown_c4's Avatar
Blown_c4
Sliding,
What is your shocks brand? looks cool an! good work.
Do you know your spring rate??
Old Aug 31, 2008 | 02:42 PM
LD85's Avatar
LD85
Originally Posted by Blown_c4
Nice!
My spring rates are set for good ride, 400 front and 275 rear .
I cant help with road course set ups
www.ndneyes.com
Old Aug 31, 2008 | 03:45 PM
Sliding's Avatar
Sliding
Sliding,
Thanks.
I also have 400 for the front as LD85. I still didn't buy rears!
Shocks are Strange Engineering.
I plan to do some road racing soon, than I'll see how it'll behave!
Old Aug 31, 2008 | 06:43 PM
BrianCunningham
Ah, makes sense.
Be cautious on the swaybar links.
If they bind up at all they'll wind up in your brake rotor.
I know several people that's happened too
Old Aug 31, 2008 | 10:57 PM
95wht6spd's Avatar
95wht6spd
Are those QA1's? Springs?
How is the ride quality?
Old Sep 1, 2008 | 02:21 AM
Sliding's Avatar
Sliding
Ah, makes sense.
Thanks for the heads up! That is the last thing that I need!
Old Sep 1, 2008 | 02:26 AM
Sliding's Avatar
Sliding
Nope. Those are Strange Engineering. I should be able to tell you
about ride quality in a couple of days, but ride quality is not
my goal. Good handling on track is my priority.
Old Sep 1, 2008 | 02:51 AM
86PACER's Avatar
86PACER
This is one mod I've been wanting to do. I also like that you can lower and raise the car at will.
I'm curious to see pics of the sway bar linkage solution.
Old Sep 1, 2008 | 06:00 AM
Sliding's Avatar
Sliding
I'll post pics as soon as I do that!
Old Sep 1, 2008 | 09:51 PM
Mo_Bandy's Avatar
Mo_Bandy
Looks great Sliding!
MO
To Coilovers installation - pics inside
Old Sep 10, 2008 | 01:59 PM
86PACER's Avatar
86PACER
Check out how Mo did it.
http://www.ndneyes.com/mo/coil.html
Old Sep 10, 2008 | 02:35 PM
LD85's Avatar
LD85
86PACER Which CO's are you looking at ?
Old Sep 10, 2008 | 02:58 PM
Sliding's Avatar
Sliding
I planed to do it like that. I've allready bought joints (pic) I just
have to measure how long threaded links I have to fab.
Thanks!
