C4 Fuel Pump will not start
Old Sep 1, 2008 | 10:01 AM
ceberus's Avatar
ceberus
Default C4 Fuel Pump will not start
I have an intermittent starting problem with my C4. The car would crank but not start. The spark was fine, but I discovered that the fuel pump was delivering 0 PSI when I would crank the car.
I replaced both the fuel pump relay and the fuel pump. The car ran fine for one day. The next morning I was back to the same problem -- the car will crank but no start. This problem only seems to happen when the car is cold.
Old Sep 1, 2008 | 10:10 AM
joseph p's Avatar
joseph p
Can you hear the pump running when you first turn the key on?
Old Sep 1, 2008 | 10:26 AM
ceberus's Avatar
ceberus
No, I can't hear anything. Even when I crank the car I get no sound from the pump.
Old Sep 1, 2008 | 10:40 AM
MK 82's Avatar
MK 82
Time to pull out your meter and your test light and do some troubleshooting.
Do you have the schematic?
Old Sep 1, 2008 | 10:57 AM
ceberus's Avatar
ceberus
Arhhg. Yes, I got the schematic. This is going to take a while. But my guess based on all the facts is the oil pressure sensor.
Old Sep 1, 2008 | 11:25 AM
engle1147's Avatar
engle1147
Could be...leave the fuel pressure gage hooked up to the fuel rail when cranking to see what is going on with the pump/fuel pressure.
Good Luck!
Old Sep 1, 2008 | 12:14 PM
MK 82's Avatar
MK 82
The oil pressure switch provides a backup source of power to the pump. It only functions when you have oil pressure. If the pump does not run when your turn the key, your problem is elsewhere.
Shouldn't take long to troubleshoot if you can read a schematic. It's a fairly simple system.
The FSM has a good troubleshooting chart.
Old Sep 1, 2008 | 12:21 PM
Onlya1's Avatar
Onlya1
I have the same problem I'm trying to figure out in the general forum. Replaced the pump, relay, ignition module, coil, cap and rotor and still no fuel to the rail. Some how no power is getting to the pump when the engine is cranked. It rotates but will not start. If you get and answer I'm in the general forum. It will help and I will do the same. Thanks in advance.
Old Sep 1, 2008 | 02:46 PM
rick lambert's Avatar
rick lambert
You should run a wire from the positive terminal of the battery to pin G on the ALDL, that's the pin on the lower left side of the ALDL, that will bypass the fuel pump circuit and provide 12 volts to the fuel pump, if it runs you know you have a problem in the circuit. I once had a similar problem, had replaced the fp relay and it failed again. Upon examination I found the wires going into the relay base (and you have to pull it from the firewall to see it) the insulation had shrunk back an inch or so and wires were coming into contact with one another...easy fix. I posted it and found out alot of guys have found this to be a problem with our earlier C4s.
Old Sep 1, 2008 | 05:48 PM
ceberus's Avatar
ceberus
Thanks!
Just to confirm we are on the same page regarding the ALDL pin, in my manual it says PIN G is for CCM diagnostics. Usually, I ground pin G to pin A to get diagnostics to display on the dash. It seems strange that it will turn on the pump? Do I have the correct pin G?
Old Sep 1, 2008 | 08:06 PM
rick lambert
Sorry dude, I looked at your profile, I see yours is a 1992 (always best to post the year) so it might be different, I think 84-91 was OBD1 and the ALDL only has one pin on the lower row...left hand side, running 12 volts to that activates the fuel pump...but, like I said 92 maybe different.
Old Sep 1, 2008 | 08:12 PM
Onlya1's Avatar
Onlya1
lambert my car is and 87.
Old Sep 1, 2008 | 08:14 PM
Onlya1's Avatar
Onlya1
How far back did you have to chase the wire from the relay?
Old Sep 1, 2008 | 09:09 PM
MK 82's Avatar
MK 82
Do you have a schematic and an FSM?
Old Sep 1, 2008 | 10:30 PM
ceberus's Avatar
ceberus
Hi Mike,
I have the FSM. Since the fuel pump will not even prime, I am assuming the problem is in the relay circuit. I am using schematics from Chart A-5 to troubleshoot the FP relay circuit.
The issue I am having at this time is that I am not smart enough in circuits to to correlate the five prongs on the relay to what is described in the diagram.
Old Sep 1, 2008 | 11:10 PM
Onlya1's Avatar
Onlya1
Sorry I don't have an FSM.
Old Sep 1, 2008 | 11:17 PM
MK 82's Avatar
MK 82
Well unless someone can post a schematic for your car you are going nowhere.
To C4 Fuel Pump will not start
Old Sep 2, 2008 | 06:38 AM
rons85's Avatar
rons85
Jumper the pump (power "hot" lead and the lead out to the Pump itself) at the fuel pump relay - that Should have the pump running constantly, as long as you leave the jumper connected.
Normally the pump will run (the relay will be "on") for 2-3 seconds after the ignition key is turned to run. That's all - 2-3 seconds. This process is controlled by the ECM. The relay is NOT on during cranking so the fuel pump does NOT run during cranking.
Only if you crank it long enough for Oil pressure to come up does the oil pressure Switch then cause the fuel pump relay to come on and run the pump. As long as there is oil pressure the relay will be held On by that switch.
Simple enough...
Old Sep 2, 2008 | 11:36 AM
rick lambert
OnlyA1, what I said about jumping terminal G will/does work for an 87 (mines an 87). As far as the wires going into the FP relay...just pull it off the firewall and look at the wires going in...my bet is you'll see what I was referring to.
Old Sep 2, 2008 | 11:52 AM
MK 82's Avatar
MK 82
Unplug the connector. Take a fused lead and attach one end to the batt pos.
touch the other end to terminal E on the connector.
Does the pump run?
