1988 Vette performance
Old Sep 3, 2008 | 12:58 PM
deerkill10's Avatar
deerkill10
Default 1988 Vette performance
I was wondering what kind of performance I can expect out of my stock 88 vette the only upgrade is the bosh 3 injectors and eliminated the midconvertor but still have the precats on. I have a 4+3 tranny with 275-40-17 all the way around(stock). I was at a stop light with a mustang and dumped the cluch at about 3500 and i was lucky to get 10 feet of rubber, It seems a little doggy in midrange 2500-3800 is this all I get for 245 horse or should I start throwing more parts at it.
Old Sep 3, 2008 | 01:18 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Bosch 3 injectors won't provide any HP improvement over your stock injectors if your stock units were good. Exhaust upgrades will help. I eliminated the precats, which are worthless, and put on a high flow main cat (this was mainly to keep noise down). You can remove the frisbee which will help a little as well. 1.6 full RR's are a good easy mod as are aluminum under drive pulleys. You could also port your intake. There are lots of threads and pics on that. Never throw parts at any car you will be disappointed.
Old Sep 3, 2008 | 01:46 PM
Spinner_89's Avatar
Spinner_89
Respectfully - I doubt that leaving rubber on the ground was your intention when racing a Mustang. If you've got a good set of rubbers, hook up the traction and go.
There are many threads on here about how to make our l98's make more power, anything that will make a big difference will cost you some $$$.
Not knowing your final drive ratio - I can't tell you the best launch rpm to use.
- - - Did you beat the mustang ? - - - Was it a comparable car ? or was it a brand new Roush ? - - -
Old Sep 3, 2008 | 02:02 PM
engle1147's Avatar
engle1147
Don't feel bad if it was one of the Ford Shelby GT500 rated at 500 horsepower from the factory.
Your old injectors fuel atomization may weak (clogged)....new injectors would bring you back to speed.
Get a free flowing exaust system...no cats if you have no emissions testing where you are.
Get a free flowing intake system....K&N style oil air filter
Need more:
Get some deeper gears in the rear
Get a cam with greater lift & duration....
Get a set of performance heads
Get some long tube = length headers
Old Sep 3, 2008 | 04:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Some 8yrs ago my '88 with an A4 was bone stock and ran very low 14s in the 1/4 mile. A few years later, with (mostly) rather simple bolt on mods, at its best it ran very low 13s.
Old Sep 3, 2008 | 05:15 PM
deerkill10's Avatar
deerkill10
the mustang won
Old Sep 3, 2008 | 05:21 PM
Kool88vette's Avatar
Kool88vette
It's easy to get into the low 13s. I have had an 1988 auto for a while. It ran a 14.4 completely stock.
My new best was 13.7. The engine is still stock. All I did was open up the intake and exhaust. I still have the stock shorty headers. I bolted on a superam, threw away the frisbee, installed underdrive pullys, a 2400 tc and 1.6 RRs.
That's all it took to take .7 off the 1/4.
Old Sep 3, 2008 | 05:57 PM
Alan777's Avatar
Alan777
I'm buying a 1988 shortly [saturday] and I'm trying to setup parts now.
I dont mean to thread jack, but General Discussion wont answer me.
I'm thinking
Melrose LT's - What Cat's will i need to run with these? I want to run cats.
Corsa Catback
And do the 1.6 RR's do anything by themselves? Or are they a "supporting mod"
Old Sep 3, 2008 | 06:10 PM
Kool88vette
I'm thinking
Corsa Catback
Better check about smog regs before you change your exhaust. Your 88 has a single main cat. Pypes has a decent bullet cat for about $60.00 each. 1.6 rrs will get you another 10 to 15 chp.
Old Sep 3, 2008 | 06:42 PM
Aardwolf's Avatar
Aardwolf
If your going to spring for the Melrose headers why not just get the whole system. They sell a bolt on dual exhaust with cats setup for use with their headers. I think it just requires your choice of mufflers.
The higher ratio rockers will help in themselves yes. You may want to replace the valve seals while your there and also get new springs. A better cam would help a bunch, plan your springs around that.
Run a search or two and possibly copy someone elses build that fits your budget and HP goal. Search for Superram or Miniram, '88 upgrades, mods, etc.
Edit, and oh yeah read Vader's site!
Old Sep 3, 2008 | 08:24 PM
Alan777's Avatar
Alan777
I haven't heard their full exhaust, but I'm in love with Corsa. I was considering Melrose, but Im just looking for a decent set of coated headers.
Cam, etc will come later, it's bolt on's for now, at least until winter, when he engine is going to be rebuilt.
I'd imagine smog will be fine. I have a Borla Catback with Labree HFC on my Audi, and it passed. I also know a guy at a garage that can pass me if anything arises.
And as far as Miniram, etc, I'm unsure. I really don't like high revving engines, after my Audi. I like the low end grunt of the TPI. My end goal will be high 12's, which shouldn't be too hard to accomplish.
Old Jul 9, 2015 | 04:06 PM
88-VETTE-L98's Avatar
88-VETTE-L98
did you remove the cats completely?
Old Jul 9, 2015 | 04:51 PM
John A. Marker's Avatar
John A. Marker
First, not sure that Kool88vette is still around on the Forum. It has been several years since he has been active. I believe that he added high flow cats because we are in California... but I may be wrong. We raced at the same track in Sacramento years ago. My cat bolted in and out. When I went to take the car to the track, I unbolted the high flow cat and bolted in a straight thru pipe. The 85 stock exhaust was very restrictive. So the cat removal and a few more bolt on's put me at 13.6 in the 1/4.
For a thread that is 7 years old, your better off starting a NEW thread to ask your question.
Old Jul 9, 2015 | 05:57 PM
Mike 92LX's Avatar
Mike 92LX
My 88 has a Hyperjunk chip,AFPR,Corsa catback,no screens in MAF,C5 Z06 wheels,CAI and an air foil. All of those mods sans catback are not worth anything and still went 13.9 99MPH with a full tank of gas. Auto with 307 gears.
To 1988 Vette performance
