Vacuum line
Old Sep 3, 2008 | 06:42 PM
jrogensk's Avatar
jrogensk
St. Jude Donor '09
Default Vacuum line
I have a vacuum line that comes off what looks like the bottom of the ASR and heads toward the back of the alternator. It is a hard plastic hose and the end looks broken, but I don't see anything it would attach to. I didn't find any reference to it in the FSM. Does anyone know where it should attach?
Here is where it connects to the ASR:
Here is the broken end:
Old Sep 3, 2008 | 08:19 PM
MK 82's Avatar
MK 82
You will get more answers if you include the year. Most folks won't go to the trouble of looking at your profile.
Old Sep 3, 2008 | 08:29 PM
MK 82's Avatar
MK 82
Does your cruise work?
Old Sep 3, 2008 | 08:30 PM
pablocruise's Avatar
pablocruise
Is your cruise control operational?
Vacuum originates from the intake manifold. You can trace from that starting point.
Sorry for such a general non-specific answer, but it will get you into the right path.
Old Sep 4, 2008 | 09:42 AM
jrogensk's Avatar
jrogensk
St. Jude Donor '09
It is in my signature. 1993 LT1.
I looked into it a little more last night and it is not part of the ASR system, it is part of the AIR system. The FSM mentions the vacuum line but there is no diagram of where the line is routed. The AIR system is only active until the engine goes into closed loop, which is probably why I haven't noticed any issues. I'm more concerned that I may have a vacuum leak where it is supposed to connect to the vacuum source.
Old Sep 5, 2008 | 04:44 PM
jrogensk's Avatar
jrogensk
St. Jude Donor '09
Anyone?
Old Sep 5, 2008 | 05:21 PM
toptechx6's Avatar
toptechx6
The vacuum diagram is under the hood on the fan shroud.
The line from the diverter valve goes to a tee located near the PCV under the left fuel rail cover.
Old Sep 7, 2008 | 11:42 AM
jrogensk's Avatar
jrogensk
St. Jude Donor '09
Thank you!
Old Nov 7, 2010 | 10:06 PM
steverichmond's Avatar
steverichmond
I just broke mine. It's kind of rigid plastic line and it runs under the fuel rail cover on the drivers side. What is it called so I can order a replacement? Any suggestions of a place to order?
93 LT1
Thanks,
Steve
Old Nov 8, 2010 | 06:20 PM
steverichmond
bump anyone?
To Vacuum line
