Pre-Cats
Old Sep 4, 2008 | 04:06 PM
mojo92's Avatar
mojo92
Default Pre-Cats
Is it bad to cut off the pre-cats and still have the main cat still on and working ?
Old Sep 4, 2008 | 04:34 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Bad is probably the wrong word. The front cat is to reduce NOx gases while the rear is for Hydrocarbons. Modern cats do both now.
If you replaced your middle cat with a new model, you'd still get both functions. (Assuming you need to accomplish both).
If you don't replace your main cat and omit the front cats, the car will still run fine.
Old Sep 4, 2008 | 05:50 PM
vader86's Avatar
vader86
Its fine. I would replace the main cat with a new one however.
Old Sep 4, 2008 | 06:24 PM
Brown vette's Avatar
Brown vette
1st Gear
I removed all mine, replaced the front "Y" with one that is without cats, and replaced the main cat as well. There are no mufflers on this car and it has LT1 tips. The interior noise is a little stout and it is has a very aggressive sound when under full throttle........but it runs pretty good!
Old Sep 4, 2008 | 06:44 PM
Kool88vette's Avatar
Kool88vette
Or you could replace your precats with 2 bullet cats like these http://www.pysales.com/iwwida.pvx?;i...0%201?comp=ppe
and replace your main cat with an X pipe.
Old Sep 4, 2008 | 09:07 PM
mojo92's Avatar
mojo92
Here some videos on how rich it is running.....it sounds like crap.......
Old Sep 4, 2008 | 09:15 PM
mojo92's Avatar
mojo92
Let me tell my story... I got the car with 192,000 miles on it I drive it home from above Atl. ( thats about 3 hrs.) the car ran fine it was just loud. The guy had drilled holes in the pre-cats cause he said they were stopped up. That Monday I had the pre-cats cut off and a week after that I had SpinTech race mufflers put on. It ran fine for about 2 weeks then it started acting up really bad. White smoke and black smoke, and the car would have like a bad lope to it driving down the road ( like if you had a really big cam and was setting at a red light where the car would want to go but couldn't ). Now I have had the motor rebuilt and everything changed and now it is running like crap ! It still has that lope to it going down the road and it is dumping gas like crazy. The guy that redone the motor did not check the ohms on the injectors nor did he check the tps nor the map sensor. My dad tested it and it had a code of 460.We don't know what the fuel pressure is nor is the timing set right,I really need some help with this if anyone that know anything about vettes and that lives anywhere around Tifton Ga., Albany or Valdosta, Macon, Alt PLEASE SEND ME A PM.
Old Sep 5, 2008 | 01:25 AM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Cats or no Cats, that car is running to RICH
A gasoline car should never smoke like a Diesel, infact new diesels don't smoke like that
To Pre-Cats
