Rear spindle yoke....1996
Old Sep 5, 2008 | 07:07 AM
Weav's Vet's Avatar
Weav's Vet
Default Rear spindle yoke....1996
I'm in the procees of changing out my rear carrier to a lower gear one. In the procees I wanted to check on the teflon washers behind the spindle yokes, change U joints etc, etc. Anyway, I thought the yoke could be removed with the half shaft by just removing the 36mm nut. It won't budge. What else has to come loose? I've tapped on it with a block of wood but still no movement. Thanks, Weav
Old Sep 5, 2008 | 07:19 AM
Weav's Vet's Avatar
Weav's Vet
I found my answer.
